Fuel Readings
Old Aug 23, 2007 | 09:58 AM
fast65's Avatar
fast65
Default Fuel Readings
I'm having a problem with finding the correct levels of fuel I have. My fuel gauge will read 3/4 when the tank is full, although it will sometimes bounce up to full. But when I get down around a half of a tank it will read near empty. My car had a new fuel sending unit put in in 2006 and I just replaced the gauges. What do you guys think it is? Is it the gauge or is it the sending unit? Thanks in advance.
Old Aug 23, 2007 | 10:17 AM
mySAVIOReigns's Avatar
mySAVIOReigns
Default RE: Fuel Readings
I would check and make sure all of the wires are fastened well. I posted about this a few days ago, if you happened to see it.
Old Aug 23, 2007 | 11:36 AM
Nabster's Avatar
Nabster
If the sending unit is working and the gauges are working, then it may be a problem with the wire linking the sending unit and the gauge. I've got a similar problem I'm going to try and get worked out by replacing the sending unit. Apparently from what I've read, if you get under the car on the back of the fuel tank whgere the sending unit it, and disconnect the wire, then turn the key the gas gauge should read nothing, then ground that wire by using another wire and touch it to bare metal somewhere else on the car to ground it, and it should read full. If that happens the problem will be the sending unit, if it doesn't then it's either somewhere in the wire or the gauge.
Old Aug 23, 2007 | 11:59 AM
fast65's Avatar
fast65
Thanks for the responses guys. Nabster, I'll try that today and see what happens.
Old Aug 23, 2007 | 02:04 PM
jlg2002's Avatar
jlg2002
ORIGINAL: fast65
New tank units are about 45 bucks plus S&H.
StalkerGT
Sep 25, 2015 02:41 PM
TfcCDR
Sep 14, 2015 12:08 PM
zanemoseley
Sep 6, 2015 12:58 PM
5.0 kevo
Sep 3, 2015 06:24 PM
SYNY5TER
Sep 2, 2015 01:35 AM
