'69 THROTTLE PROBLEM
Old Feb 7, 2005 | 06:46 PM
JBradley500's Avatar
JBradley500
Default '69 THROTTLE PROBLEM
Ever since the carburetor has been changed in my 69 CJ (4 years ago), around 3,000-3,200 rpm’s the throttle has been sticking. It was a stock carburetor, but it was changed it to a Holley 850, I was wondering why this could be. I didn’t know if the linkage or anything along those lines could need to be changed because of the new carburetor. Is the return spring the only thing could cause this problem?
Old Feb 7, 2005 | 06:51 PM
horseshoeing's Avatar
horseshoeing
Default RE: '69 THROTTLE PROBLEM
I have a throttle problem too. Every time I get into my mustang, It wants to go like hell.
You could get a bigger return spring. Could it be the carb.?
Old Feb 7, 2005 | 07:36 PM
69mach1377's Avatar
69mach1377
Try a 2nd, but light spring from the front, attach to a valve cover bolt...
Old Feb 8, 2005 | 02:18 PM
SCRATCHY30's Avatar
SCRATCHY30
Perhaps it is idiling too high.
Old Feb 8, 2005 | 03:20 PM
Soaring's Avatar
Soaring
I ♥ Acer
Check to see if any of the linkage got bent while putting on the new carb. Also, try some spray lubricant on all the moving sections to see if that will free it up. Spray silicone is good for these kind of things.
Old Feb 9, 2005 | 12:33 AM
JBradley500
After I made this post I went to check out the return spring. It seems to be in decent shape, and when I thought about it, the only way to get the car back to idle was to quickly hit and release the throttle. When I did this the throttle went back to the idle possession but it still was at the high RPM’s. This definitely means that the problem is in the carburetor itself. Thanks for the help anyway.
Old Feb 9, 2005 | 11:25 AM
69FECoupe's Avatar
69FECoupe
Are you using a stock manifold or a stock carb spacer? If so, the larger throttle blades on that 850 may be rubbing on the spacer or manifold.
Old Feb 10, 2005 | 10:47 AM
JBradley500
The car has a stock 428 intake, but soon its going to get a medium rise 427 aluminum intake. when the intake gets changed ill look to seee if the blades are rubbing.
Old Feb 10, 2005 | 11:57 AM
Soaring's Avatar
Soaring
I ♥ Acer
How about the choke butterfly? Is it open all the way when hot?
TfcCDR
Sep 14, 2015 12:08 PM
Sep 8, 2015 11:50 AM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
zanemoseley
Sep 6, 2015 12:58 PM
5.0 kevo
Sep 3, 2015 06:24 PM
