what order to get this stuff?
Old Aug 29, 2007 | 08:00 PM
69stangcoupe's Avatar
69stangcoupe
Default what order to get this stuff?
ok so i made a list on the parts i want for my engine and i no i cant get them anywhere near to all at one time soo if i were to get all of these things in what order would i be able to get them and add them to my car, and or what parts should i do at one time?
or what parts should i get in a bundle and put a couple on at a time?
650 Speed Demon carburetor
MSD ignition
Hooker 1 5/8-inch long-tube headers
3-inch MagnaFlow Mufflers
Billet MSD distributor
Plug wires
Blaster coil
1.6 ratio roller rockers
XE266HR cam from comp cams
Edelbrock Performer RPM Air Gap intake
TFS Twisted Wedge aluminum heads
Old Aug 29, 2007 | 08:37 PM
Tony R's Avatar
Tony R
Default RE: what order to get this stuff?
I would start from the inside and work out and in order that they are assembled.
Old Aug 29, 2007 | 08:48 PM
opie2@aol.com's Avatar
opie2@aol.com
I would throw a carb on there first. You will notice a big difference there and have a more fun car to drive. A 2barrel carb just won't breathe enough...Then go with the headers and exhaust to breathe a little more...You might notice enough hp difference here that you won't care as much about the rest of these things. Finish it off with an intake, rockers then ignition...
Old Aug 29, 2007 | 09:48 PM
JMD's Avatar
JMD
ORIGINAL: 69stangcoupe
2 650 Speed Demon carburetor
3 MSD ignition
1 Hooker 1 5/8-inch long-tube headers (1 5/8" might be overkill... )
1 3-inch MagnaFlow Mufflers
(IMO 2 1/2" is enough, wont catch speed bumps so much)
3 Billet MSD distributor
(or HEI? HEI will take care of MSD ignition, dist, coil, for about $150.00)
3 Plug wires (or when needed)
3 Blaster coil
2 1.6 ratio roller rockers (?)
2 XE266HR cam from comp cams
2 Edelbrock Performer RPM Air Gap intake
2 TFS Twisted Wedge aluminum heads
(Will your pistons work with these?)
My .02....
bradleyb
Nov 27, 2015 07:50 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Drastang
Sep 30, 2015 03:48 AM
GLOCKer
Sep 28, 2015 07:36 AM
