help plz
Old Aug 30, 2007 | 11:01 PM
guybored's Avatar
guybored
Default help plz
first of all im sorry for asking another tire question,my question is would this fit a 1965 coupe:
Wheel Style: FR500 Wheel Size: 18x9"
Wheel Backspacing: 5.85" Wheel Offset: +24mm
Bolt Pattern: 5 x 4.5 inch
thanks all help appreciated, i dont want to drive 1hr 20 mins then try them on and then to find out they dont fit
[/align]
Old Aug 30, 2007 | 11:11 PM
mySAVIOReigns's Avatar
mySAVIOReigns
Default RE: help plz
not without some bodywork
Old Aug 30, 2007 | 11:23 PM
five pt oh's Avatar
five pt oh
I don't think that would fit very well. 5.85" bs might be enough to run it into your inner fender. I'm not sure what the most you can do is, but I think 5.85" is likely to be beyond the max. You can always pop a wheel off and measure how much roomthere isthough, provided someone doesn't post up what the max bs can be.
Beyond that (let's pretend the 5.85" will fit), the idea backspacing for a 9" rim would be 5.25". That way the rim would center up in the wheel well.So with 5.85 you'd be sitting more than 1/2" too close to the center of the car. That means the tire you're able to fit on there will be smaller than what someone would usually put on a 9" wide rim.
If you really want to use those rims, you should find out if you can get away with 5.25" back spacing (someone here is bound to know the answer to that), and then get .30" spacers to let the rims sit in a more ideal location.
btw: the 5 x 4.5 patter is correct.
Old Aug 31, 2007 | 01:49 AM
andrewmp6's Avatar
andrewmp6
heres a little chart http://www.dodgestang.com/Tire%20Fit...ide%2065-6.pdf
Old Aug 31, 2007 | 06:11 AM
JamesW's Avatar
JamesW
By the time you got the backspacing right to pull it up under the wheelwell, the back of the tire will be hitting the inner fender housing. So no...it won't work. Adding this photo as a point of reference...
Old Aug 31, 2007 | 09:03 AM
guybored's Avatar
guybored
thanks everyone for your response, i guess ill forget about themill just keep looking hopefully ill find some before my b-daycuz they are suppose to be my present
[/align]
getnmineinmay
Apr 6, 2005 12:15 PM
supertrooper4
SVT Forums
Sep 18, 2004 03:24 PM
mustang_2004_65
Oct 21, 2003 11:18 PM
