Transmission rebuild failure.
Old Sep 3, 2007 | 08:43 PM
1971 Coupe's Avatar
1971 Coupe
Default Transmission rebuild failure.
Ok, so about 2 weeks ago I though I blew up my transmission because it was slipping so bad that I could not really go faster than 15-25mph, well now that I rebuilt my transmission it will grab in first gear, but will not shift into seccond, now im thinking that maby my tourq converter is bad....please help....and suggestions will help.
Thanks.
Old Sep 3, 2007 | 09:11 PM
Mr. Classic EFI's Avatar
Mr. Classic EFI
Default RE: Transmission rebuild failure.
The information is a little thin, what elseYa got?
Old Sep 3, 2007 | 09:17 PM
Curse The Sky's Avatar
Curse The Sky
Dumb question, but I've seen a few people get so discouraged or upset that they forget... Have you checked the fluid level / color?
Is it grinding badly, or did you have any previous HARD shifts? Do you normally floor it from a dead stop to get the nice little hop from the extra torque created by the torque converter?
Old Sep 3, 2007 | 09:24 PM
1971 Coupe's Avatar
1971 Coupe
Yes I have fluid, I just rebuilt it, and yes my car was running when I cheacked it, I have had no hard shifts, but yes I do floor it quite often.
Old Sep 3, 2007 | 09:34 PM
Mr. Classic EFI
If these symptoms started with your rebuild & reinstall. There is probably a problem in your valve body. Even small mistake there, like a check ball not in the right spot, can result in real trouble.
This linkhttp://www.network54.com/Forum/260730/ is to the Ford Transmission Forum, they deal in nothing but Ford Trannys. Try posting there, with as much information as possible. Like what kind of tranny, C-4? And what exactly you did(Just replaced clutch discs??), and when the symptoms were first noticed.
Old Sep 4, 2007 | 12:03 AM
JMD's Avatar
JMD
A "no shift" situation is almost certainly not a torque converter issue.
Like EFI says, it is probably a valve body issue.
Old Sep 4, 2007 | 10:50 AM
cprstreetmachines's Avatar
cprstreetmachines
Could be valve body, or the seals in the direct...did you open the VB during the rebuild.
Old Sep 4, 2007 | 10:55 AM
bluovalguy's Avatar
bluovalguy
You didnt use silicone when you rebuilt it did you? I did the first time I rebuilt mine cuz I didnt know any better, and it completely screwed it up.
Old Sep 4, 2007 | 01:35 PM
TexasAxMan's Avatar
TexasAxMan
You didn't reuse the old torqueconverter did you? I've heard from tranny guys that that is a definite no-no.
Old Sep 5, 2007 | 01:44 PM
jlp66stang's Avatar
jlp66stang
Had mine rebuilt, put it in, shifted one time stuck in second gear even in park. Corrosion in valve body. Took it back in the car. They took it apart fixed it . Its good now, no charge!
4cylinderplus2
Oct 9, 2020 07:45 PM
Dathan
Oct 5, 2015 05:52 AM
Drastang
Sep 30, 2015 03:48 AM
wraith777
Sep 28, 2015 10:49 AM
