Anyone running a 347 Stroker with 8" rear end?
Old Sep 7, 2007 | 04:31 PM
ldollar's Avatar
ldollar
I ♥ Acer
Default Anyone running a 347 Stroker with 8" rear end?
Hey
I picked up my first Mustang about a month ago. Ive got a 347 Stroker,newer C4 Trannyand a recently rebuilt 8" rear end. I figure I am putting out somewhere between 330-380 hp. Anyone out there running a similar setup?
Everything on it has about 18k miles and is running really good and feels really solid.
I have had a lot of people tell me that the 8" is inadequate but I would like to hear some firsthand experience. I am not racing this thing and tend to drive relatively conservatively. Rarely ever stomping on the gas from a standstill but when I have, it takes it like a champ so far.
Is this thing going to break or can it handle this for awhile? If it does break, what exactly is going to happen? I am hoping to get some opinions based on experience. Thanks guys.
Old Sep 7, 2007 | 04:36 PM
superdavid's Avatar
superdavid
Default RE: Anyone running a 347 Stroker with 8" rear end?
If (when) it does break, you're going to be towing your car home! I know this from personal experience. I was lining up to race a prowler out of a stoplight, and I started to do a burnout and my whole 8" blew apart on me. My buddytowedme about a mile to my shopin his Xterra.
Old Sep 12, 2007 | 04:19 PM
SPD DMN's Avatar
SPD DMN
Mine is in the building stages but I an going to be running the stock 8" rear with an Auburn posi and 4.11 gears. I expect the tires I will be running will give up long before the rear will. I am anticipating my 347 to run about 350 rwhp.
Old Sep 12, 2007 | 08:38 PM
cprstreetmachines's Avatar
cprstreetmachines
if you want first hand experience then here you go.
#1 rear end- stock 8", stock gears, stock one wheel wonder - blew as I turned a corner and gas it, spiinning the tire 30-40 ft and shift to second. cracked the housing so much I didn't notice it till I went to lunch at work and noticed my car was leaning down bigtime on the driverside as if I had A flat tire.
#2 rear end- 8" with an aurburn locker and 3.55 gears- blew the ring and pinion. taking off from a stop sign and then easing into it and hitting second.
#3 rear end- 8" 4.11's with auburn locker- blew the locker into 2 pieces with the ring and pinion still ok but the axles ate the crap out the the housing.
the 3 rearends were taken out from a 306 with 10.5:1 compression, Edelbrock RPM heads, custom cam, rpm intake and 600 holley carb that put down 313rwhp /331rwtq. spinning the tires isn't the part thats going to kill you, its when the tires stick is when it goes KABOOM!
#4 rear end- currie 9" 31 spline 3.50's trac loc still going strong with the new motor. 347 canfield heads 9:1 compression and the turbo that put down 402rwhp/503rwtq @4200rpms spinning the wheels on the dyno.
The rear end know is the last thing I'm worried about blowing and i'm always driving the car hard where ever I go.
Old Sep 12, 2007 | 08:50 PM
Vikefan88's Avatar
Vikefan88
i have a 347 stroker with a stock 8 inch rear end with 3.40 gears... and i have traction bars... so far i havent had problems but i havent floored it.. if i were uid look into replacing it with the solid 9 inch rear end...thats wat im a do...
Old Sep 13, 2007 | 12:57 PM
jspagna1's Avatar
jspagna1
I've heard that 8" rearends are good up till 400 horsepower range. You will have to take into account if the rearend is old & beat or if you beat the hell out of it, it's not going to last.
Tyoung68
Aug 25, 2015 04:31 AM
91StangOwner
Aug 20, 2015 11:34 PM
Black_GT_02
Aug 20, 2015 01:26 PM
92 5.0stang
Aug 13, 2015 06:46 AM
PearlGenPu
Aug 12, 2015 01:57 PM
