what exactly is a stroker kit?
Old Sep 7, 2007 | 07:12 PM
Mustang.'s Avatar
Mustang.
Default what exactly is a stroker kit?
the simple question here is just how it sounds. what is a stroker kit? sorry if that is a dumb question. but i want to know what is included in most typical 331 and 347 stroker kits? and what is the differance in a cast kit?
Old Sep 7, 2007 | 07:35 PM
Daze's Avatar
Daze
Default RE: what exactly is a stroker kit?
A stroker kit comes with a different crank, and most likely different pistons and connecting rods. Some kits are designed to work with stock pistons. It really depends on the kit, but most of the time those three things are different.
Old Sep 7, 2007 | 08:07 PM
RGH69's Avatar
RGH69
Also, the reason they call it a "stroker" kit is because it usually increase the stroke of the piston.
Old Sep 7, 2007 | 08:12 PM
easttennmotors's Avatar
easttennmotors
ORIGINAL: RGH69
stroke is based on the crank not the piston.
Old Sep 8, 2007 | 07:16 AM
NaughtyGeek's Avatar
NaughtyGeek
The crank determines the stroke of the piston.
Cast vs forged is a matter of weight and strength. The lower the weight and higher the strength, the more RPMs you can safely turn on a properly balanced engine.
The following link is to a great article on stroked engines from the FAQ section on this site.
http://www.mustangmonthly.com/techar..._engine_build/
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
flash_xx
Oct 16, 2015 07:23 AM
Drastang
Sep 30, 2015 03:48 AM
