converting a 66 2bbl 289 to a 4bbl
Old Sep 8, 2007 | 03:04 PM
07stangv6's Avatar
07stangv6
Default converting a 66 2bbl 289 to a 4bbl
ok I have a 289 2bbl V8, that i would like to restore to specs, but i had an idea. I know that the 289 4bbl V8 has a 10.0:1 CR as well as the four barel carb. Are these the only differences? Or does it have an entirely different valvetrain layout like the HO? Basicaly is it possible to turn my 2bbl into a 4bbl?
Old Sep 8, 2007 | 03:53 PM
Starfury's Avatar
Starfury
Default RE: converting a 66 2bbl 289 to a 4bbl
Same engine aside from the pistons, intake, and carb. All you need to do is pick up a 4V manifold and carb. For a mostly stock engine, I'd recommend an Edelbrock Performer (cangrind off thebrand name and paint blue to match factory if you want)and either an Edelbrock 500CFM or Autolite 4100 (1.08 venturi) carb.
Old Sep 8, 2007 | 03:57 PM
Guitylerham's Avatar
Guitylerham
I just completed the conversion and it was a no brainer. Get the manifold, swap out the old one and replace it, then get the 4bbl carb and bolt that on. Done! Ask if you need any help.
Old Sep 8, 2007 | 04:19 PM
sixtysix's Avatar
sixtysix
do you fell a big difference with the 4v instead of the 2v? Thanks Scott
Old Sep 8, 2007 | 05:42 PM
07stangv6's Avatar
07stangv6
its about 25 hp difference with the 10.0:1 CR pistions. and its 4 barrel not 4 valve. 4 valve would take a lot of custom fabbing
Old Sep 8, 2007 | 05:53 PM
68SCode4speed's Avatar
68SCode4speed
Definately feela difference. I remember seeing it in print somewhere that the swap will give you a 2 second drop in the quarter mile.
Use a stock Ford Intake manifold as the parts you have now will bolt up directly where they do on your 2 barrel intake manifold. If you use an aftermarket intake (granted they are LOTS lighter) you might have parts bolting up in different locations. Don't know for sure since I swapped on a stock manifold- someone who did the aluminum intake swap will have to answer that question.
Check out this link and if you do the swap I'd highly recommend doing it just like this - I use the same procedures and mine is perfect with no leaks. http://www.mustangsteve.com/intake.html
If you can find an Autolite 4100 carb that has the 1.08 venturi's (480 cfm) then I'd use that otherwise the 1.12 (600 cfm) would probably be too much cfm for your motor. Follow this link and read up on the performance difference. These guys at Pony Carbs know their stuff. http://ponycarburetors.com/default.a...amp;category=2
Make sure to search and read all the links on their page that you can find - take your time as there is very good info on their website about the 4100 carb.
They took my Autolite 4100 (1.12) and did the spreadbore conversion (made it a 1.00 venturi with plastic sleeves)on it. The carb sits on a stock289 motor with a stock Ford 4 barrel intake & Tri-Y headers. Run freakin' great!
Old Sep 8, 2007 | 06:56 PM
68SCode4speed
More than I would pay but here is the complete setup...
http://cgi.ebay.com/ebaymotors/Ford-...QQcmdZViewItem
Old Sep 8, 2007 | 10:19 PM
htwheelz67's Avatar
htwheelz67
the stock 4v intake is not a performance manifold, get an edelrock performer or better a wieand action plus and a 500-600 cfm carb, for a stocker a 500cfm edelrock carb is perfect or a 525 road demon. Dont worry about parts lining up the throttle linkage may need some adjustment thats about it.
You will pick up about 25-30 hp with that swap and 1-2 mpg's on the hwy, you can paint the manifold blue and put your stock air cleaner on if you want it stock looking.
Old Sep 8, 2007 | 10:31 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Who mentioned valves? 4V stands for 4 Venturi, and 2V stands for 2 Venturi.
Changing a 302/289 to a 4-valve setup is as simple as swapping heads, actually. They are very expensive, but are worth while, from what I've seen. Don't know if the heads are still in production or not.
ORIGINAL: 07stangv6
Old Sep 9, 2007 | 05:58 AM
Gary H's Avatar
Gary H
[quote]ORIGINAL: Colorado_Mustang
ORIGINAL: 07stangv6
http://www.araoengineering.com/ used to make the 4 valve heads, not anymore. Just 351c for fords and at 12K for the setup I doubt they're worth it.
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
lovesilver
Members Mustangs
May 9, 2019 09:18 PM
jerrytubes
Oct 23, 2015 12:11 PM
guitarman376
Sep 30, 2015 05:54 PM
