Complete C3 to T5 conversion
well it all depends on who is doing the labor and what knowledge they have with mustangs. I know you need a new t-5 bellhousing and the t-5 tranny can come out of a fox body stang, i think
1600 is too low thats a junkyard t5 and a home made cross member probaly id look http://www.keislerauto.com/ford/mustang65-70.html and http://www.moderndriveline.com/ theres a few more out there tho.
I spent 3 grand, and thats on parts alone, but they're all the best parts. Rebuilt t5 from Texas Motorsports, Centerforce Dual Friction clutch, hydraulic clutch kit, etc. I did the install my self, its not hard. If I were to do it over again I would just buy a kit from Modern Driveline, plus then you have their tech support.
Part
Cost
Location
T-5 Transmission
$ 800.00
Rebuilt T-5 from Rosehill Performance
T-5 Bellhousing
$ 50.00
Ebay
Cable Clutch Kit
$ 259.00
Modern Driveline/NPD
Clutch Pedal and Assembly
$ 130.00
National Parts Depot
T-5 Crossmember
$ 149.00
Flywheel
$ 100.00
Autozone (No core)
Clutch Kit
$ 110.00
Autozone
C4 Tranny Mount
$ 8.00
Autozone
Total Cost
$1,606.00
I don't think the C4 tranny mount will work, you need to get one from someone like Modern Drive Line.
I bought the kit from them, about $3000 I think. It really isn't too hard to do, but get someone to help that has installed a clutch before. My buddy and I tried it, neither of us had done a clutch before, and I blew it, and had to do it again.
I think mine cost about $2000, and thats doing just about everything myself.
1. Used t5 with bellhousing and likenew FRPP King Cobra clutch...$500
2. Replace input shaft, 2nd gear, cluster gear, bearings, and general rebuild + s10 tailhousing (going into a Falcon) ...$800
3. Modern Driveline crossmember...$149
4. Modern Driveline clutch cable (now burned by ill-fitting headers)...$259
5. Hurst pro-billet Camaro shifter...$200
6. Incidentals (pilot bearing, bolts, oil, mount, etc)...~$100
7. Grand total....~$2,000
8. Future costs...(replace clutch cable, headers that actually fit, modify brand new exhaust to fit said headers, etc)....~$600 [:@]
It can certainly be done a lot cheaper, especially if you know how to fabricate and can find good used parts and are lucky enough that they are still useable.
6, body, c3, conversion, crossmember, cyl, driveline, forum, fox, modern, mustang, s10, swap, t5, tailhousing, transmission
