rear main seal?
Old Sep 11, 2007 | 10:57 PM
Vikefan88's Avatar
Vikefan88
Default rear main seal?
i have leakage out of a 302 in a 65 mustang...the leaking is droppin on the starter an down the starter and also on th side of the oil pan ....could it be the rear main seal? or the oil pan gasket? how cani detect if its the rear main seal..shouldnt the drippin be running down the front of the tranny down the middle?
Old Sep 12, 2007 | 04:45 PM
SPD DMN's Avatar
SPD DMN
Default RE: rear main seal?
Sounds like the valve cover gasket. Best thing to do is clean the area off as best you can and watch for new wet areas to form.
Old Sep 12, 2007 | 06:58 PM
Vikefan88's Avatar
Vikefan88
i have cleaned of the area and it sitll dripps ontop of the starter and the side of the starter closest to the pan....you think its the ooil pan gasket...or the rear main seal?..... as for the valve covers.. i have brand new rubber gaskets.. should i get cork and put silicone?
Old Sep 12, 2007 | 07:20 PM
9teen65coupe's Avatar
9teen65coupe
I had a leak that was similar to yours and it turned out to be my valve cover gasket. I went back with rubber though and everything turned out fine.
Old Sep 12, 2007 | 07:36 PM
blue66mustang's Avatar
blue66mustang
+1
Had the same exact problem last weekend. New Fel Pro gasket leaked at the back of the valve cover just above the #4 header . Driped right on the starter. If you GLUE the gaskets down use a black flexable sealer. The red high temp works great but looks like CR@p if a little squezes out .
Good luck.
Old Sep 12, 2007 | 08:42 PM
Vikefan88's Avatar
Vikefan88
hmmmmm.... so should i stick with the new rubber gaskets.. or cork gaskets..... and because the ones i have now are new.....
Old Sep 13, 2007 | 09:33 AM
SPD DMN's Avatar
SPD DMN
If they are new rubber, just try to R&R the gasket again with some new RTV.
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
Demodulates
Sep 18, 2015 11:14 AM
Sep 16, 2015 07:53 PM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
