weird problem 66'
Old Feb 18, 2005 | 12:52 PM
juniorb_41's Avatar
juniorb_41
Default RE: weird problem 66'
ya thats an odd angle but it is in just like that. when you say take it out and see if it cools you mean right after I run it to see if it opens up? because i tried putting it in again and watched it overheat and the intake manifold, before the thermostat, feels very hot but the radiator tubbing out of the thermostat feels suprisingly cold. I tested my thermostat out of the car and it opens up at 180 degrees farenheit like its supposed to. So im thinking maybe i need one that opens earlier? I dont know
Old Feb 18, 2005 | 02:26 PM
horseshoeing's Avatar
horseshoeing
No, 180 is what you need.
I was talking about running your car without a thermostat to see if it is the thermostat.
Old Feb 18, 2005 | 06:59 PM
juniorb_41's Avatar
juniorb_41
i said 180 didn't I?and yes i ran it without and it stayed very cold almost at the cold line.
Old Feb 19, 2005 | 03:05 AM
Magiarn71's Avatar
Magiarn71
Throw the stat in a pot of boiling water and see if it opens. It is entirely possible that it's junk out of the box, had that prob before. I know it's the second one you've tried, but I'd check it anyway just to eliminate the possibility.
Old Feb 19, 2005 | 01:52 PM
juniorb_41's Avatar
juniorb_41
ya i did that before i ever put it in the car. im thinking about just trying a restrictor plate eventhough their not as useful
Old Feb 20, 2005 | 10:41 AM
Buzz's Avatar
Buzz
Maybe you're getting an air lock in the systyem. Just a thought.
Old Feb 20, 2005 | 03:34 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: Buzz
Now, that is a possibility. Try "burping" the system. Take off the cap and let her run at idle until all the bubbles are gone. (It has to get hot enough for the thermostat to open) It seems to me though, that if the thermostat is in properly, and it works, then it should be cooling. But, you say it runs cool without the thermostat. Hmmmmm. I would suspicion the thermostat itself under those conditions.
Old Feb 20, 2005 | 06:27 PM
juniorb_41's Avatar
juniorb_41
yesterday i got it working and you guys got it right it was the air lock i needed to leave the cap off for a while so that it would cool down. thanks for all the help
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
2015Ecoboost
Sep 17, 2015 01:48 PM
MasterLanMan
Sep 13, 2015 08:21 PM
