Early vs Later Engines..
Old Sep 30, 2007 | 11:44 PM
takeoutexodus's Avatar
takeoutexodus
Default Early vs Later Engines..
Ok , So what would be better a later roller block ? like 90's
or an early stronger block ? 69-80's
these plans are not surpassing 400 hp..
and we are of course talking about a 351w .
is the roller block worth it ? or is it too weak as people may say ?
is there a difference?
this is staying a carburated set up .
thanks
Old Sep 30, 2007 | 11:52 PM
67mustang302's Avatar
67mustang302
Default RE: Early vs Later Engines..
At 400hp it won't matter. The roller block would be preferable since a factory roller setup is cheaper than a roller conversion kit
Old Oct 1, 2007 | 12:00 AM
takeoutexodus
Also, do you know when the 4 bolt mains became the standard thing ?
Or what years it was offered?
Also, do you know if they have any 90's non dual overhead cam 351w's ?
whats the main advantage of a 4 bolt main instead of a 2 bolt.
Old Oct 1, 2007 | 12:11 AM
67mustang302
I don't think they ever made 351W's with 4 bolt mains on factory engines(except perhaps the 5.8 Cobra R's, but I doubt even that). All the Windsor family is cam-in-block, they never had OHC. 4 bolt mains are more stable, but only necessary in very high power and rpm applications. The vast majority of street applications are fine with just a plain ol 2 bolt bottom end. 4 bolt 351W's can be had from ford(Sportsman and 351R blocks) but you're gonna spend over $1,500 for a bare unprepped block, they're good for anywhere from like 800-1,800hp depending on the block
Old Oct 1, 2007 | 05:30 PM
takeoutexodus
thank you very much .
so i guess for an application of around 400 hp all you really need in any block even from the 90's?
Old Oct 1, 2007 | 07:01 PM
67mustang302
Yes. There are people making 500+hp on factory 80/90's 302 blocks reliably, and the 351 block is obviously stronger
Old Oct 1, 2007 | 08:13 PM
Mr. Classic EFI's Avatar
Mr. Classic EFI
ORIGINAL: 67mustang302
+1
4 bolt mains?? Ya been readin, too many Chebby magazines.
Old Oct 1, 2007 | 08:29 PM
takeoutexodus
i see i see.
thanks
lincolnshibuya
Dec 8, 2015 04:37 PM
FivePointToTheOh
Oct 2, 2015 04:09 PM
yourmom6990
Sep 14, 2015 10:52 PM
FivePointToTheOh
Sep 14, 2015 03:35 PM
