Dizzy Question
Old Oct 3, 2007 | 12:00 PM
jeffro22's Avatar
jeffro22
Default Dizzy Question
what distributor should i get for my 67 289. Everything that i am finding is either a steel gear or a points distributor. I would like to go HEI . I can't spend $400 for a msd one either. Can the gear off of a steel distributor be replaced to work with my iron cam gear I still have my old distributor, it isn't in good shape but the gear looks ok.
Old Oct 3, 2007 | 12:04 PM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
Default RE: Dizzy Question
just rebuild and save up until u can get a bitchin one.
Old Oct 3, 2007 | 12:17 PM
JMD's Avatar
JMD
I am a big fan of the HEI Distributors, they will work great and are more than adequate unless you are doing some serious racing. They are very reliable, relatively cheap to buy, and are very cheap to maintain should you have a failure. Repair parts are available (and in stock) in virtually every parts store in America.
This one has a cast iron gear already....
http://store.summitracing.com/partde...p;autoview=sku
Old Oct 3, 2007 | 03:31 PM
ponyX65's Avatar
ponyX65
yeah,just save up youre money like USMCrebel said it will be worth it. Last thing you want is to waste money on somthing youre not happy with.
Old Oct 3, 2007 | 04:45 PM
Starfury's Avatar
Starfury
I don't really see a problem with the stock unit. With an electronic ignition upgrade and an advance recurve it'll work just fine.
That said, I have an MSD ready-to-run and 45kV coil in my 331 and I love it. It comes with everything you need to change the advance curve to pretty much whatever you need, and it's easy to add a box later if you want.
Old Oct 3, 2007 | 04:59 PM
restomod66's Avatar
restomod66
How about a Duraspark II Conversion??
Old Oct 3, 2007 | 06:51 PM
plainsman1876's Avatar
plainsman1876
Just use the stock one , and put a points eliminator problem solved
Old Oct 4, 2007 | 09:04 AM
jeffro22's Avatar
jeffro22
what is a points eliminator??
Old Oct 4, 2007 | 10:12 AM
valley firearms's Avatar
valley firearms
Spend a $100 and get the Pertronix conversion unit. I had mine installed in about 30 minutes. You will have to eliminate your pink resistor wire from your ignition and run a 12V wire to reliably power it. You won't regret it. Your car will idle and start better. Most performance auto parts stores will carry these.
http://pertronix.com/
[align=left] [/align]
Old Oct 4, 2007 | 11:09 AM
Starfury's Avatar
Starfury
The standard Pertronix does not require the resistor bypass, it will run fine on 8V. The Pertronix IIunit, however, does require a full 12V to function properly
