verifying a true GT???
Old Oct 20, 2007 | 12:06 AM
david01130's Avatar
david01130
Default verifying a true GT???
Its a 66 mustang. supposedly a GT. I know almost all of what a GT consists of and It has all of it (A code, quick steering, fogs, badges, stripe, etc) except Im confused about the dual exhaust hanger part. On this car there is a hole and when I stick my finder in I can feel the suppor towards the back of the car. I didnt feel towards the front of the car but I heard it is suppose to be towards the front of the car not the back. Whats right? The hole is also on the bottom of the frame and I heard its suppose to be on the side of the frame. Is this a GT?
Old Oct 20, 2007 | 06:18 AM
gjz30075's Avatar
gjz30075
Default RE: verifying a true GT???
http://www.karmustang.com/factory_gts.php
Tip #1 should nail it for you, including the brake line routing. If you can get the rear seat out, check for the reinforcing plates on the floor for the hangers. Not the little vertical plates the studs use but the large sheet metal one. Good luck.
Old Oct 20, 2007 | 12:17 PM
ky's Avatar
ky
America ftw
yes if the reinforcing plate is toward the REAR of the car then its a gt. and yes its supposed to be on the bottom. also check in the front radiator support for two holes for the fog lamp wiring. pull up the carpet and rear seat and if there is two bolts under the butt of each seat on each side then thats the dual hangers = gt.
Old Oct 20, 2007 | 12:30 PM
david01130's Avatar
david01130
Is it wasy to pull of the seat on a fastback? Do I just pull up the bottom cushion?
Old Oct 21, 2007 | 08:11 AM
gjz30075's Avatar
gjz30075
Just push the cushion rearward and then pull up. It can be tricky.
vargas
Jun 17, 2017 12:17 PM
winner99
Sep 30, 2015 07:04 PM
treesloth
Sep 28, 2015 07:03 AM
2015Ecoboost
Sep 17, 2015 01:48 PM
TfcCDR
Sep 12, 2015 04:13 PM
