carb replacing
Old Oct 24, 2007 | 06:48 PM
6mustang6's Avatar
6mustang6
Default RE: carb replacing
timing is supposed to be at TDC or alittle advanced for power... right?
Old Oct 24, 2007 | 07:49 PM
bluovalguy's Avatar
bluovalguy
I have a little sputter also and I would like to try a spacer, but I dont have room under the hood[:@]
Old Oct 25, 2007 | 12:14 AM
Hawkins 812's Avatar
Hawkins 812
I have the same problem every now and again as you baxsom. I also believe i have too much carb for my 390(770cfm) so i will be changing it out over the winter and adding a 1-2in spacer.
BTW...what is the difference in the 1" spacer compared tot he 2" spacer. Also, would it be better off to get a plastic spacer for heat control or would it not matter on a street engine? Just curious...
-Hawkins
Old Oct 25, 2007 | 12:30 AM
67mustang302's Avatar
67mustang302
The bigger the spacer the greater the effect. As far as sputters, coughs, hiccups etc when you crack the throttle rapidly, that's an accelerator pump tuning issue. Gotta mess with cams, squirters etc to get it right. Wideband O2 monitering helps a lot, I wish I had one
Old Oct 25, 2007 | 05:33 AM
baxsom's Avatar
baxsom
ORIGINAL: 67mustang302
yeah i kinda figured that the biggest problem is that the pump is spraying too much fuel.
you have to mess with the cam, cam placment, squirter size etc
i was told that the 390cfm comes jetted smaller with a smaller shot off the acell pump to begin with so there would be less trial and error needed.
god i hate carbs. if this car wasnt all orignal and my father in law wasnt the original owner id convert to EFI
5.0muscle
Jan 11, 2016 01:17 PM
9550
Oct 26, 2015 05:01 PM
tramphardrocker
Sep 13, 2015 08:56 PM
MusicCity615
Sep 12, 2015 07:05 AM
Art161
Sep 9, 2015 10:33 AM
