Removing lower valence?
Old Oct 24, 2007 | 02:07 PM
66 PNY's Avatar
66 PNY
Default Removing lower valence?
I am starting to tear apart the mustang for restoration, and am having a difficult time with the lower valence retaining clips. They look like there there to align the valence with the body as they are also attached to the front fenders. Everytime I turn them they just lift that particular body part up or down. Is it that they are just old or is there a trick to them?
Old Oct 24, 2007 | 02:19 PM
jlg2002's Avatar
jlg2002
Default RE: Removing lower valence?
I don't recall having mounting clips on my valance. They just bolt on using bolts and nut clips. sounds like your nut clip is turning.
Old Oct 24, 2007 | 02:23 PM
Hawkins 812's Avatar
Hawkins 812
Same here. Only my chrome trim uses the clips.
Old Oct 24, 2007 | 03:08 PM
RolandT3Speed's Avatar
RolandT3Speed
The clip are probably corroded. Be careful removing them that you don't bend the sheet metal.
I had to use a liberal amount of WD-40 and vice grips to hold the clips so as to avoid bending the metal.
I had to hack saw one off.
jwog666
Dec 27, 2021 08:09 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
baddog671
Jul 26, 2016 01:20 PM
Dathan
Oct 5, 2015 05:52 AM
UrS4
Oct 3, 2015 06:23 AM
