Carb Problems
Old Oct 26, 2007 | 05:15 PM
Starfury's Avatar
Starfury
Default RE: Carb Problems
Probably not. You need to get a tune kit for the carb. It will include most of the rods, jets, and springs you'll need to get that ironed out.
Old Oct 26, 2007 | 10:15 PM
redhawkk's Avatar
redhawkk
I think the Edelbrock AFB has design problems. I bought a new Edelbrock AFB to replace an old Carter AFB on a 67 Stang 289. Never could get it to start/run right.
First off, I could not get the idle speed down slow enough. Finally I did, but not reliably. Then there were choke problems and starting problems. This was all quite a few years ago, and I no longer recall the details. However, I recall discovering that there was a jambing problem with the shafts and stamped parts that controlled the choke, fast idle cam, etc.
The problem was, the stamped parts were too wimpy to hold their shape. The spring in the mechanism was too stiff, and in a short time, one of the stamped parts would bend and then get jambed up on the shaft. I could straighten it out, but it would soon bend again. I eventually gave up and replaced the AFB with an Autolite 4100.
Old Oct 26, 2007 | 10:30 PM
Starfury's Avatar
Starfury
An Autolite 4100 is certainly a much simpler and easier to tune design, but there is no design problem with the current Edelbrock choke linkage. I don't know what stamped parts you're talking about; there are rods and a couple cams, everything cast and bent into shape. They're plenty sturdy for the extremely small load placed on them. I have zero problems with my Edelbrock.
uberstang1
Sep 20, 2015 06:42 PM
Sminemann
Sep 17, 2015 09:24 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
jaiidutch
Sep 14, 2015 10:29 AM
tramphardrocker
Sep 13, 2015 08:56 PM
