Braking "problem"
Old Oct 25, 2007 | 12:09 AM
Hawkins 812's Avatar
Hawkins 812
Default RE: Braking "problem"
ORIGINAL: Kramer
ORIGINAL: 350kmileFord
Basically, if a car brakes harder in the front, then the rear "is going faster then the front" as my auto teacher put it. The "faster moving part of the car will want to get ahead of the slower part"-this put it in dumb terms for us. So your fronts are probably doing more stopping then they should. A properly-tuned proportioning valve should fix the problem.
you know, the funny thing is usually when the rears lock up the vehicle whippes around, not when the front's lock up.
I agree. It makes sense the wayHE phrased it though.
Old Oct 25, 2007 | 08:39 AM
kalli's Avatar
kalli
drive normal, hit the brakes normal (not like emergency stop). If your steering stays straight while you're doing that, then most certainly the proportioning valve.
Old Oct 25, 2007 | 11:12 AM
Starfury's Avatar
Starfury
We still don't know if he has drums all the way around, or if it's a disc/drum system. A 4 wheel drum system won't have a proportioning valve and doesn't reallyneed one. You do the adjustments at the wheel with the star adjusters. Even with the disc-drum setup you can get some adjustment out of the rears this way. I suspect this may be all he needs to do; back off the star adjusters a little and it might fix the problem.
Old Oct 25, 2007 | 05:37 PM
bluovalguy's Avatar
bluovalguy
He has disc front, and drum rears.
Old Oct 25, 2007 | 06:25 PM
Mustang Dad's Avatar
Mustang Dad
OK Hawk, here we go. With disc in front and drums in the rear, you need an ajustable pressure relief type valve in the rear line, I.E. a proportioning valve. Normally front discs need more pressure to operate than drums. If you had drums all around and then replaced the fronts with discs later in life and didnt install a proportioing valve (or a combo valve) then the rears would tend to lock up and you would loose control of the vehicle. This is because drum brakes dont require as much pressure to operate them discs. A combo valve is simply a distribution block with a proportioning valve built in. It really sounds like you dont have a proportiongi valve in your rear line. Under normal circumstances this isnt a big deal, but with a panic stop, its a REAL big deal. A combo valve or proportioning valve will be located near your master cylinder...it will have about 5 or 6 lines runing in and out of it, maybe even have a small electrical connection. A proportioning valve will be down stream of your master cylinder and have only 2 line connections....in and out, with a small nurled **** for making adjustments. The best way to adjust both thypes of valves is to adjust it fuly counter clockwise and go out and drive the car. Slam on the brakes and see which set locks up first. front or rear. If its the fronts, then adjust the knurled **** in one turn and try itagain. Keep doing this until the rears lock up first and then back off 1 turn so that the fronts lock first. After that your all set. Hope this long winded explanation helps and sorry for making if over long guys.
Old Oct 25, 2007 | 06:29 PM
350kmileFord's Avatar
350kmileFord
Did something I say confuse someone? I didn't mention any brakes locking up.
But if the rears did lock up, it would mean that they have virtually no stopping power compared to the front, so the rear would want to maintain its velocity. I never mentioned the fronts locking up.
Tivo304
Aug 28, 2023 12:19 PM
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
mungodrums
Oct 7, 2015 04:01 AM
musnicki
Sep 23, 2015 07:11 AM
