coil spring compressor
Old Oct 27, 2007 | 06:36 PM
Daze's Avatar
Daze
Default RE: coil spring compressor
ORIGINAL: free70coupe
Thanks for all the responses. I will probably go with the homemade version Daze suggested.Thanks Daze. I figure I only plan on using the tool once to remove the old ones and once to put in the new ones so I will save alot of money doing it myself.Thanks again Daze for the link with the instructions!
MAKE SURE THE WELDS HAVE GOOD PENETRATION. IF YOU ARE A GOOD WELDER THAN BY ALL MEANS, BUT IF YOU ARE NOT SURE OF YOUR WELDING SKILLS MAKE SURE YOU FARM IT OUT. I know lots of people have fabricated up the pieces and then taken them to a certified welder to be finished up. welding the all-thread to the square tubing is easy to get good penetration. the base is thicker and holds all the pressure so make sure the bottom piece has really good penetration
firehorse02
Nov 16, 2015 11:28 AM
fastbackford351
Oct 1, 2015 12:24 PM
mungodrums
Sep 28, 2015 10:54 PM
Sixer4Life
Sep 28, 2015 07:05 AM
