holy pcv!!!!!
Old Oct 27, 2007 | 06:14 PM
pinboy122's Avatar
pinboy122
Default holy pcv!!!!!
hey all i have a 65, built 289,dual quad,roller rockers,old school cal-custom valve covers.my problem is oil leakage thru the breather caps.i tried adding gaskets,new gromets etc.the covers dont have baffles.my question is,do i need pcv to eliminate my oil leak or do i just need to fab some baffles.the oil seepage is enough to cause probs,but i really want to keep the look of the old school covers.im just baffled no pun thanks al
Old Oct 27, 2007 | 07:22 PM
capt.redbeard's Avatar
capt.redbeard
Default RE: holy pcv!!!!!
Does it leak all the time or just at high rpm? A friend of mine had an s-10 with a 11to1 comp. 350 that would blow oil out the dipstick tube at high rpm. He switched to circle track valve covers that had dual breathers and the problem went away.
Old Oct 27, 2007 | 07:49 PM
Starfury's Avatar
Starfury
You need a funcitonal pcv system. Without one, you're blowing all of the crankcase gases out the breathers, not to mention the crud building up in your crankcase that should be sucked into the intake and reburned. There is no reason not to run a pcv valve.
Old Oct 27, 2007 | 09:06 PM
pinboy122's Avatar
pinboy122
starfury,that pretty much confirms what i was thinking,thanks
Old Oct 28, 2007 | 01:02 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Your PCV system will suck in some of the oil, but it isn't your solution.
You need the baffles. The oil is just splashing in the right spot. I don't run PCV systems on my toys, and they don't suffer one bit.
Old Oct 28, 2007 | 05:30 PM
67mustang302's Avatar
67mustang302
If you drive the car regularly I'd get a pcv. A pcv on one valve cover and a breather on the other. The pcv will evacuate all the craproducts of combustion out of the crankcase and help the oil and block last longer. You do need baffles though
JonnyBlazeGT
Nov 3, 2015 01:10 AM
lmurf60
Sep 24, 2015 10:07 PM
Ipaman
Sep 22, 2015 07:01 AM
Scottyboy187
SVT Forums
Sep 13, 2015 10:23 PM
YoungStangsMan
Sep 5, 2015 07:01 PM
