Steering Wheel Removal
Old Oct 29, 2007 | 06:01 PM
65Sickster's Avatar
65Sickster
Default Steering Wheel Removal
I have a 65 mustang. I need to know how you remove the steering wheel from the column. Any special tools I need? Thanks in advance!
Old Oct 29, 2007 | 06:28 PM
mat11089's Avatar
mat11089
Default RE: Steering Wheel Removal
disconnect the battery,take the horn ring off by pushing it in and turning,next the the nut off the steering shaft,then use a steering wheel puller,insert one bolt then the threaded puller and thent he other matching bolt,tighten the long threaded puller til it pops off.When you put it back on make sure te orientation is correct then push on and and just tighten the nut onto the steering shaft.You want to disconnect the battery cuz otherwise things will spark if u ground the horn contact.The steering wheel puller is a universal and is only like 8 bucks.
Old Oct 29, 2007 | 06:36 PM
65Sickster's Avatar
65Sickster
Thanks! In order to get the "orientation correct" does that just mean lining up the steering wheel staright with the wheels? What's the best way to accomplish this? Should I eyeball the steering wheel as straight as possible with the tires straight?
Old Oct 29, 2007 | 06:48 PM
mat11089's Avatar
mat11089
yes and yes eyeball it and be prepared ot have to do it a few times cuz theyre are so many splines on teh shaft adn in the steering wheel there are so many options so youll probably get off ive done steering wheels sooo many times and although ive improved it still takes a couple shots.but u got the right idea
Old Oct 29, 2007 | 07:01 PM
65Sickster's Avatar
65Sickster
Thanks again for your help! Much appreciated!
Old Oct 30, 2007 | 10:59 AM
crunchyskippy's Avatar
crunchyskippy
I know this may be a little late...
But I was able to massage my wheel off by using my knees without much difficulty. (Didn't have a wheel puller and nothing was open on Sunday night.) Also be sure to torque the wheel nut back on to the correct specs. Naturally this spec escapes me now... I had my work loose on me as thecorrect torquewas tighter than I guessed.
Good luck.
Old Oct 30, 2007 | 11:09 AM
Hawkins 812's Avatar
Hawkins 812
Heres a couple links in our FAQ that mention some good tips on removing the sterring wheel;
Steering Wheel restoration:
http://www.dealsonwheels.com/parts/garys/
How to remove the steering column and replace the steering box:
http://www.fordmuscle.com/archives/2...x/index2.shtml
BOBCATJACK
Sep 14, 2015 02:18 AM
wawagner82
Sep 13, 2015 09:02 AM
Sep 10, 2015 08:39 PM
Sep 8, 2015 11:50 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
