Door questions
Old Nov 11, 2007 | 05:31 PM
64to66's Avatar
64to66
Default Door questions
How many of you have relaced your door skins? I am thinking about it but there is really only surface rust on the bottom. it hasn't eaten through yet... but, the inside of the door has rust as well.
Has anyone tried to just rust treat the inside of their door without taking of the skin? i have plenty of por15 and would like to save the money...
also, has anyone used a complete door replacement? mustangs unlimited has them.
Old Nov 11, 2007 | 05:35 PM
smittycm's Avatar
smittycm
Default RE: Door questions
If you've got plenty of POR 15, then I don't see why you couldn't just treat the inside of the door yourself. I've never tried it myself, and I imagine it would be a royal PITA, but I don't see why it couldn't be done so long as you removed all the guts of the door. I'd rather do that than shell out the money and fart around with a whole new door shell. I had enough trouble lining up the original doors after replacing hinges. I couldn'timagine trying to line up an aftermarket door.
Old Nov 11, 2007 | 05:38 PM
6marc5's Avatar
6marc5
Ihave never re-skinned a door,butI did buy a complete shell from NPD. It fit really nice and the woodgrain was good. If I remember right it was about $350.00 or so. Also check out ebay,craigslist,swap meet,ect. and you might be able to pick up a good used one.
Old Nov 11, 2007 | 11:31 PM
F14chuck's Avatar
F14chuck
Last winter I treated the insides of my door shells. Used a dremmel for the small areas. Ate up quite a few bits and grinding wheels in the process. Ran a shop vac during process to keep the dust/rust from migrating. Used rust converter afterwards. Its definitely cheap and buys you time before the inevitable. I've been doing this for the last 18 yrs. on various parts of my69 vert daily driver with pretty good results.
If you do this, dont grind all the way to bare metal. Needs some rust to react with. The label has directions and is avail at walmart for $4a can.
Old Nov 12, 2007 | 09:52 PM
64to66's Avatar
64to66
Well, this gives some time to think on it. I am worried that treating the rust i won't be able to get every nook and cranny inside the door....
Old Nov 12, 2007 | 10:50 PM
choefle's Avatar
choefle
The inside of the doors will be a real pain to coat entirely, but this would give you time before you have to replace the skin or a complete shell.
We installeda complete shell from NPD on a budy's 66 coupe. Thefit was great and it is already EDP coated, which will help prevent future rust.
Ipaman
Sep 22, 2015 07:01 AM
accarter
Sep 21, 2015 11:56 PM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
SYNY5TER
Sep 2, 2015 01:35 AM
