Explorer EFI
Old Nov 16, 2007 | 12:16 PM
rj's Avatar
rj
Default Explorer EFI
Hey guys (gals),
New to the website. I have a '65 coupe with a 5.0 carbureted engine that I eventually would like to convert to EFI. Has anyone done this with the Explorer intake? I understand that it is the tallest of the 5.0 intakes but also the best performer. I want to make sure that there will be enough hood clearance for it. Thanks.
Old Nov 16, 2007 | 03:52 PM
JamesW's Avatar
JamesW
Default RE: Explorer EFI
should work fine. I don't think it's any higher than a GT40 intake and they will clear.
Check out my website for some general EFI info.
Old Nov 16, 2007 | 10:10 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
make sure to pirate hte heads from a 96-97 explorer also
Old Nov 16, 2007 | 11:51 PM
gothand's Avatar
gothand
Hey RJ,
I'm in the process of converting to EFI at the moment, and coincidentally, am using an Explorer intake. I, too, was concerned about height until I measured the height of the manifold. It is slightly shorter than my current RPM Air-Gap manifold/Edelbrock AVS carb/hi-po air cleaner combo.
I'll post some pics once I get mine underway.
Jeff
Old Nov 17, 2007 | 02:46 AM
67mustang302's Avatar
67mustang302
It's a shame Ford no longer makes the GT40 intakes and is being stingy with the patent and won't let anyone else make them. Not only did they perform really well, but they looked sexy.
Old Nov 17, 2007 | 08:18 PM
Mr. Classic EFI's Avatar
Mr. Classic EFI
The ACT(air charge temperature sensor) will need a mount drilled into the Exolpder lower, or mounted close to the MAF like the newer cars.
My Exploder intake is going on now.
Old Nov 17, 2007 | 09:05 PM
JamesW's Avatar
JamesW
I'm holding out for that 100 buck GT40 I'm going to find at the swap meet someday
Old Nov 17, 2007 | 09:53 PM
67mustang302
ORIGINAL: JamesW
Swap meets and Ebay are pretty much the only places you'll find them now. There used to be a few extra unused ones floating around, sold new several years ago, but even those are all gone now. I haven't seen but 1 on Ebay in the last year and a half. One of the best street intakes ever made for a EFI SBF. You can still get the GT40 lower from Ford(unless they d/c'd it) but the uppers are no where to be found.
Old Nov 18, 2007 | 12:35 PM
gothand's Avatar
gothand
ORIGINAL: Mr. Classic EFI
Any reason not to put it in the upper intake? My lower doesn't have the flat boss for drilling and tapping.
Good luck on the manifold find James. It seems people really know the value of these things. I have yet to find a 5.0L Explorer intake, A9L computers, GT40 heads or anything else of real value as "bargain bolt-ons"in any of the pick-n-pulls that I frequent.
I got my Explorer intake for $200, an Accufab TB for $81 and a Pro-M MAF, airtube and K&N for $46 off of Ebay. Sniping and poorly worded listings are your friend.
Jeff
69Volunteer
Sep 30, 2015 10:39 AM
Ipaman
Sep 22, 2015 07:01 AM
waid302
Sep 14, 2015 11:19 AM
jaiidutch
Sep 14, 2015 10:29 AM
YoungStangsMan
Sep 5, 2015 07:01 PM
