Need help on axles!
Old Nov 19, 2007 | 06:54 PM
baddog671's Avatar
baddog671
Default Need help on axles!
So I got my new housing for my rebuild I'm doing and I didnt notice at first but then later I saw a rubber seal at each end inside the bearing housings. I ASSUMED this was the axle seals so I bought a seal puller and then quickly realized that maybe these aren't the axle seals. They are pretty thin and shaped to seat towards the center(if that makes any sense) and have a small spring on the inside (looks exactly like a woman's hair scrunchy). I think I may have screwed it up becuase the spring fell out the oneside. Anyone know what these are?I think I should figure out how to get that spring back in and leave them alone...
I was confused becuase I thought it went axle retainer,bearing, seal---not retainer, seal, bearing..
Ill get pictures if need be, but I think the spring should be a giveaway?
Nic
Old Nov 19, 2007 | 07:00 PM
69FECoupe's Avatar
69FECoupe
Default RE: Need help on axles!
What you are describing IS the axle seal. It presses into the axle tube.
Old Nov 19, 2007 | 07:02 PM
baddog671's Avatar
baddog671
Wouldnt that seal the oil away from the bearings, and burn them up?
Old Nov 19, 2007 | 08:27 PM
69FECoupe's Avatar
69FECoupe
It does seal the oil away from the bearings. They are not lubricated by gear lube. They are the sealed lifetime lubricated type.
Old Nov 19, 2007 | 08:32 PM
baddog671's Avatar
baddog671
Ok, sealed bearings, thats what I told my dad but he didn't think it would be that style in the 60's...
Hmm, so what should I do...tear them out and try to find a shop to press new ones in, or try to fit that spring back in(if possible)and leave them alone? They look in decent shape
Old Nov 19, 2007 | 11:03 PM
baddog671's Avatar
baddog671
Bump...
I found some help on another forum aswell and now I understand whats going on lol. I tried popping them out but these ****'s are in there good. Any suggestion? I have the 10" seal puller tool but its like pushing a brick wall. I did get the metal rim of the seal to dent up in one spot, but thats it...
KingRando
Oct 2, 2015 08:06 AM
marc954
Sep 29, 2015 11:18 AM
lincolnshibuya
Sep 24, 2015 10:46 PM
Sep 24, 2015 09:18 PM
Sep 10, 2015 08:39 PM
