C4 to T-5 swap?
RE: C4 to T-5 swap?
I'm looking into doing a T5 swap myself and ran across this website that has lots of good info. and parts:
www.moderndriveline.com
If your trying to save money (like me)check out your local wrecking yard. I stopped byPick N Pullyesterday afternoon for a quote and if I pull the parts myself it's $112.00 which includes the T5, bellhousing and clutch cable!
You can also have them pull the parts for an additional cost. Parts & Labor = $280.00 total.
Either way......it's a helluva lot less than $1200 for a reman. transmission! Plus the swap parts you need.
Good luck!
Good luck!
RE: C4 to T-5 swap?
Yea i looked at modern driveline, really good stuff, but i already have the tranny...i actually am pullin the 302 out of my 84 stang and puttin the engine and WC T-5 in the 66' the only thing im kinda concerned with is the clutch pedal. I have TCP mounts in the 66 now, so those r staying, the tranny crossmember is easy to get, the driveshaft isnt hard to come by either, even if its custom made. im lookin for a original clutch pedal setup, any idea where to get one for cheap???
Matt's 95 Stang
10-05-2015 07:16 AM
