I Hate undercoating
Old Nov 22, 2007 | 12:28 AM
baddog671's Avatar
baddog671
Default RE: I Hate undercoating
No, you dont NEED to. Its just a thin layer of undercoating, it doesnt do that much really.
Underlayment will do much more
Old Nov 22, 2007 | 12:43 AM
SalikDDD's Avatar
SalikDDD
the limited amount of undercoating my car has we're just knocking it off with a needle scaler, it falls right off.
Old Nov 22, 2007 | 06:11 AM
67 evil eleanor's Avatar
67 evil eleanor
If you can a friend that has a steam-pressure washer (Landa), it will make life easy. Without the heat, the pressure washers don't do much.
Old Nov 22, 2007 | 09:41 AM
rst08tierney's Avatar
rst08tierney
I removed mine with almost zero elbow work. I used a presure washer with "HOT" water. I then por15 the bottom and re did the undercoating(used dynamat undercoat spray). I then did the entire inside of the car with the spray too, followed by using the dynamat sheets all over the bottom of the car. To be honest with you its the best think I ever did for my mustang. The car stays SOOOOOOO much quiter now and also stays warmer. If I had to put a % on how quiet the car is now, I would say 60% more quiet. The trick is a thick smooth coat on the bottom and a thin even coat on the top so you can apply the dynamatsound proofing. The job cost about $200.00 to do. (100 for the dynamat and 75 for the spray.) Yes I used the spray cans.
Old Nov 22, 2007 | 09:49 AM
baddog671's Avatar
baddog671
100 bucks for dynamat? got a link?
Old Nov 22, 2007 | 11:09 AM
dirtydave289's Avatar
dirtydave289
I just finished my driver's side fender and am working on the passenger side now of my '66
I'm using a 3-4" wire wheel with my drill and a wire brush with a metal scraper some too, it's working real well
End result is definitely worth it
guitarman376
Oct 11, 2015 01:47 AM
69MustangCoupe393cid
Oct 3, 2015 10:33 AM
Ipaman
Sep 22, 2015 07:01 AM
ccdguy
Sep 19, 2015 05:20 PM
BrantleyS550
Sep 14, 2015 04:18 PM
