camshaft
Old Nov 23, 2007 | 02:21 AM
67mustang302's Avatar
67mustang302
Default RE: camshaft
Those cams concentrate allthe power in a real low rpm range, best for towing where you get high torque, and good low end power, but no top end. And you don't need a super torque towing cam to do burnouts.
Old Nov 23, 2007 | 12:00 PM
1970coupe's Avatar
1970coupe
ahaha. def not gonna be towing in a 70 coupe.
i wanna build it more for torque. so couldnt this work? the whole kits about 90.00
Old Nov 23, 2007 | 04:02 PM
67mustang302
You'd be better off with a cam that has an rpm range that goes up to 5,500 or 6,000rpm. Like 2,000-5,500 with a good street cam design, it'll make good torque everywhere. Wider lobe seperation angles work well, they produce slightly less peak power, but better torque across a wider rpm range, narrower lsa's tend to make more power, but concentrate it in a narrower rpm range. You don't need a big cam to make big power, but you also don't want to go too small, otherwise it'll have good bottom end torque, but fall flat on the top side.
djbigskrilla
Sep 20, 2022 01:04 AM
NYstang
Sep 30, 2015 09:56 PM
uberstang1
Sep 20, 2015 06:42 PM
2003 4.75l
14
Aug 29, 2015 02:58 AM
Redneck1465
Aug 8, 2015 10:39 PM
