Replacing Vinyl Top
Old Mar 16, 2005 | 01:29 AM
iveka44's Avatar
iveka44
Default Replacing Vinyl Top
I am going to replace the vinyl top for my hardtop coupe (1969). I found this part at the following website: Link
How do these tops usually come? Are they conformed to the proper shape and you simply attach them? Do you use any sort of adhesive?
Thanks for your help!
Old Mar 17, 2005 | 03:14 AM
metalfloyd's Avatar
metalfloyd
Default RE: Replacing Vinyl Top
I am prty sure that they are attached with some kind of adhesive. I know my 67 had a vinal top and it seems like that is how it is on there.
Old Mar 17, 2005 | 05:10 PM
vfast's Avatar
vfast
I ♥ Acer
yes....the old comes off and not easy..you will need to scrape off all the old glue to make for a smooth surface....then use thinner and a clean white rag before applying the glue..you must then stretch the vinyl over the top
Old Mar 17, 2005 | 05:52 PM
Soaring's Avatar
Soaring
I ♥ Acer
The cover should come with the proper adhesive. But, yes, you do need to use an adhehive. The cover should be slightly wider and longer than you need, so trimming is necessary. Just make sure you have solved any rust issues before putting on the new cover.
Tivo304
Aug 28, 2023 12:19 PM
5.0muscle
Jan 11, 2016 01:17 PM
Art161
Sep 9, 2015 10:33 AM
kawiguy827
Sep 1, 2015 07:09 PM
