fine tuning issues need help!
Old Dec 25, 2007 | 12:12 AM
dave45's Avatar
dave45
Default fine tuning issues need help!
ok heres the deal guys.
i had this car running a couple months ago and then i had to replace the intake and now its giving some hella problems.
i have a 1971 mustang with a 302. i redid the motor stoked it out made it a 331put a mid range cam in it a high performance intake and it has a 625 cfm edlebrock carb. it has a electric fuel pump regulated at like 7-8 i think.
my issues are i found top dead center, i made sure my fireing order was right, i even had it running for a bit but i have no clue what my timing degree should be at for this engine. i dont know if i should adjust the timing or the carb first. on the carb i have to jet needles which i backed out 2.5 turns for a start i dont know what to set the idle at to start and i havent a clue how to set the electric choke on this dam thing.
i had it running tonight but it was studdering when i put some gas to it. so i fooled with things a bit and i must have made the mixture to rich because the plugs fowled out. im going to track down some plugs tomarow but i could realy use some help in finding out where i start with this car and the order in which i tune things so i dont screw up some more plugs. i have a strobe timing light. a feeler gauge the only thing i dont have is a dwell meter.
i could realy use someone to walk me through this im doing this car a an xmas present to a freind and hes coming back from out of town on saterday. so far ive redone the engine the interior the body all i need to do is tune the dam thing and it should be good to go.
thanks guys,
dave from tulsa
Old Dec 25, 2007 | 02:51 AM
Mustangdemon67's Avatar
Mustangdemon67
Default RE: fine tuning issues need help!
im going through the same thing you are..
with your build a good timing i think would be around 10 degrees. and for the carb, 2-3 turns of that little idle screw is good, but maybe your carb just needs new gaskets?
Old Dec 25, 2007 | 03:12 AM
dave45's Avatar
dave45
well the carb i just rebuilt but im not used to points and gapping them im not used to this electric choke and setting it but i will set it to 10degrees thanks
Old Dec 25, 2007 | 08:35 PM
dave45's Avatar
dave45
no one else has any advise?
Old Dec 25, 2007 | 10:07 PM
67mustang302's Avatar
67mustang302
Always set timing first. And get a good book on carburetor tuning, you need to learn how a carburetor works if you want to be able to tune it so it works well. There's a lot more to it than just setting idle screws.
Old Dec 26, 2007 | 03:01 PM
bluovalguy's Avatar
bluovalguy
I lived in tulsa about 9 years ago. It was an ok place.
Set your timing first. Than, as far as the carb goes, try this if you have a vacuum gauge. If not, they are only about $20 and any parts store.
http://www.fordmuscle.com/archives/2...ockCarburetor/
Also, if you go to edelbrock's website, there are a bunch of tuning tip videos there to help you out.
djbigskrilla
Sep 20, 2022 01:04 AM
mstahoo
SVT Forums
Aug 19, 2021 09:15 PM
drfister
May 3, 2018 10:38 PM
mweiland
Aug 13, 2015 05:11 PM
fdnyems19
Aug 13, 2015 09:36 AM
