Starting Issue
Old Dec 29, 2007 | 05:01 PM
dozierstang's Avatar
dozierstang
Default Starting Issue
Ok, so I had re-wired the 67 with a ron francis kit, hooked everything up exactly as instructions said. Put all my fluids in to start it up and nothing. I have power to my ignition switch and to all my accessories. But no start. Nothing, not even a click. Checked all connections, good. Those of you that have a RF system. How is your starter solenoid hook up. The "S" and "I" on the solenoid do not have any wires per the instructions. Is this right? Oh, new battery, new solenoid, new cables all redone. I also double checked the neutral safety and all seems good. The start wire from the ignition switch goes to the fuse panel / neutral safetyswitchper instructions. Seems like it should also go to the "S" terminal on the solenoid. Any suggestions?
Old Dec 29, 2007 | 05:52 PM
dozierstang
Default RE: Starting Issue
Well, figured it out...Found one of my instruction sheets that I apparently missed. Well only the wire that runs from the "S" on the solenoid to #3 on the panel. Makes sense now. The starter wire from the ignition switch runs to#4 on the panel. Neutral safety runs to #3 and #4 on the panel. So, to complete the circuit, a wire must run from #3 to the switch. Oh, well, I guess we all have are dumb moments.
djbigskrilla
Sep 20, 2022 01:04 AM
mstahoo
SVT Forums
Aug 19, 2021 09:15 PM
drfister
May 3, 2018 10:38 PM
5.0 kevo
Sep 3, 2015 06:24 PM
1st 4 eyed fox
Aug 24, 2015 06:56 PM
