200 to 250 6 cyl swap
Old 01-01-2008, 05:01 PM
68goldstang
68goldstang's Avatar
Default 200 to 250 6 cyl swap
We have a 68 200 6 cyl auto coupe. The motor was gone when we purchased it. I am looking for a motor to replace it and was offered a 250 out of a 70 Stang from a friend. I was wondering if I can use that motor in our car and what would I need to make it work. I don't have them side by side so I can't tell. Is there any advatage to using the 250 over the 200 ?
68goldstang is offline
Old 01-01-2008, 05:07 PM
ky
America ftw
ky's Avatar
Default RE: 200 to 250 6 cyl swap
you can do this:
ky is offline
Old 01-01-2008, 05:13 PM
JMD
JMD's Avatar
Of course the extra 50ci is a good thing! It is my understanding that it is a straight forward and bolt in swap that will also give you the advantage of going with an aftermarket intake. The 200 intake is cast with the head, and as I understand it, the 250 uses a bolt on intake.
(that six looks pretty good true 66)
JMD is offline
Old 01-01-2008, 07:02 PM
68goldstang
That motor is sweet! I had been told I would have to swap my trans as the bellhousing is diff and the starter is in a diff location and on and on.
Old 01-01-2008, 07:03 PM
ky
America ftw
ky's Avatar
well if its that complicated, you might as well put a mild 289 in it then.
ky is offline
Old 01-01-2008, 07:26 PM
az1966
az1966's Avatar
check fordsix.com, they will give you the straight stuff, if memory is right the head is taller on the 250 vs the 200 so hood clearance issues could show up ,,,you can also try classicinlines.com for help
az1966 is offline
Old 01-01-2008, 08:47 PM
1slow67
ROTM Moderator
1slow67's Avatar
ORIGINAL: az1966
I am a member on there. There will be some issues with the hood. There is 1 section on there that shows a pic of it. The 250 was sticking out above the fender.
1slow67 is offline
Old 01-01-2008, 08:48 PM
ky
America ftw
ky's Avatar
get a sweet 3 inch cowl hood.
ky is offline
Old 01-01-2008, 09:25 PM
68goldstang
Well the car is for our teenager /first time driver and the Girlfriend thinks he needs a six to keep him form getting in trouble. I'm still trying to fingure out that way of thinking. We have a parts car with a full V8 drivetrain
Old 01-01-2008, 09:31 PM
ky
America ftw
ky's Avatar
give him a v8! it aint THAT fast. a stock 289 or 302 would be perfect.
ky is offline
baddog671
07-26-2016 01:20 PM
Bokeo
10-10-2015 08:28 PM
b8checker
10-08-2015 12:55 PM
Matt's 95 Stang
10-05-2015 07:16 AM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
Quick Reply: 200 to 250 6 cyl swap
