pros and cons
Old Jan 2, 2008 | 11:47 PM
restomod@16's Avatar
restomod@16
Default pros and cons
Ok I want to hear your opinions on the pros and cons of a
351W (obviously more CI but more power?)
and a
347 stroker
Old Jan 2, 2008 | 11:54 PM
JERM_1967stang's Avatar
JERM_1967stang
Default RE: pros and cons
about eqaul power just like a 289 to a 302. but the 351 is more reliable any stroker engine isnt as reliable as the base cid blocked engine
Old Jan 3, 2008 | 12:00 AM
ky's Avatar
ky
America ftw
347 will make more power compared to a stock 351. the crank specs on a 347 is almost identicle to a chevy 350, so if u build a 347, youre pretty much building a 350. i was gonna build a 347 for my stang but decided to go back to the stock setup. but my next motor will deffinately be a stroker motor.
you can stroke the 351 to a 408 and make buttloads of power. if u keep it stock bore, itll last longer than the 347 because, well, its stock.
if you go with the 347 with afr heads, a nice cam, headers, good carb+intake, you can make about 430hp. which is plenty for the street.
ive never looked into a 351 so i dont know much about em. i just know alot about 347s cause i was planning on building one for a couple months now just up unitl a few weeks ago i changed my mind .
Old Jan 3, 2008 | 12:16 AM
andrewmp6's Avatar
andrewmp6
Both depend on your budget what power you want out of it or what you want to do with the car.
Old Jan 3, 2008 | 10:05 AM
109jb's Avatar
109jb
ORIGINAL: true66gt
While a 347W strokermotor can be made to make more power than a "STOCK" 351W, a 351W can be made to make more power for less money and be more reliable. That 347 that makes more power, what kind of heads, intake and cam does it have? If they are stock from a 302 then it ain't gonna make more power. Will it make more power than a 351W with comparable heads, cam, intake, compression ratio, etc. I think not.
The 347 motor has a .030 overbore and an additional 0.4 inches of stroke giving a bore and stroke of 4.030 x 3.4. The The stock 351W motor has a stoke bore and stroke of 4.00 x 3.5. At 0.030 overbore, the 351 has a displacement of 357 cu. in. Right there you have 10 cu in more and you can do all of the other mods like cam, heads, intakes and on and on to the 351 and you haven't paid for a stroker crank, rods, pistons, etc. In my opinion, you canbuild a 351W to make as much or morepower than a 347 for less money.
Old Jan 3, 2008 | 10:08 AM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
ORIGINAL: true66gt
b/c the is a 346ci motor 5.7l
everything depends on what you want to do a 347 will make more power compared to the stocker 351 b/c of ci if you change the cam lifters porting and stuff like that. the 347 will yield about 320-340 hp ~300rwhp +/- with stock parts from the 302 placed back on (ie intake heads cam) to reach those levels with a 351 with far far greater torque change the cam .450+ intake dual plane for torque, and single for higher rev and higher RPM band HP. If you want to save some money, just home port your heads..it does take a while but you'll notice some gains. or if you got some $$$ laying around look into patriot/ AFR with 185cc heads
JoshyGT
Sep 19, 2017 08:52 PM
mapitts
May 11, 2016 10:14 AM
jerrytubes
Oct 23, 2015 12:11 PM
PB Pod
Forum Issues and Feedback
Sep 17, 2015 08:32 PM
Doogie65
Sep 6, 2015 02:55 PM
