oil pressure reading
Old Jan 14, 2008 | 09:16 PM
reluvseor's Avatar
reluvseor
Default oil pressure reading
Just bought a 68 coupe 6 cylinderfor the wife and trying to keep it running without blowing it up. question is - the oil gage is readingall theway to the left while the car is running. The reading on the dip stick is one quart low. Is this a problem and if so what is the remedy?
Old Jan 14, 2008 | 09:25 PM
mustanglover66's Avatar
mustanglover66
Default RE: oil pressure reading
low oil pressure normally comes from worn rod and main bearing. I would drop the pan and replace them it not a difficult job in these old stangs. I would also change the oil pump while your in there they don't cost to much and droping the pan is 3/4 of that job anyways.
but try installing a machical gage first to rule out a bad gage or sensor.
Old Jan 14, 2008 | 10:10 PM
jc92073's Avatar
jc92073
Are you hearing any ticking or knocking noises from the engine? Hook up a manual gauge asap and see what you really have.
Old Jan 15, 2008 | 03:07 PM
jlg2002's Avatar
jlg2002
+3 on the issue. It may just be a gauge issue, but you need to chck for a noisy engine and mechanical pressure. Throw a quart of cheap oil in there just to be safe.
mtgldr
Feb 3, 2024 09:00 PM
StalkerGT
Sep 25, 2015 02:41 PM
MusicCity615
Sep 12, 2015 07:05 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
Sep 8, 2015 11:50 AM
