what flywheel do i need?
Old Jan 15, 2008 | 10:20 AM
jonm1a1's Avatar
jonm1a1
Default what flywheel do i need?
I have a 65 mustang with a c4 automatic transmission and a 289. The 289 has to go (hole in piston wall). I am replacing it with a 1987 302 that had a manual in it. So with that said can i use my 28oz flywheel off my 289 or do I need to get a new one all together.
please excuse my ignores, I am learning about engines and transmissions by all this stuff. You guys are always great thanks a lot
Old Jan 15, 2008 | 10:39 AM
TexasAxMan's Avatar
TexasAxMan
Default RE: what flywheel do i need?
As I understand, you will need a 50 oz imbalance flywheel. Others will chime in if I'm wrong, and a lot will even if I'm right. Stay tuned ......
Old Jan 15, 2008 | 12:29 PM
Mustero's Avatar
Mustero
You WILL need a 50oz offset flywheel.
Old Jan 15, 2008 | 12:40 PM
JMD's Avatar
JMD
Yep,,, a 289 flex / flywheel will not work in a post 1984 5.0 /302.
If going with the C-4 you will need a flexwheel..
For a manul trans you will need a flywheel...
Old Jan 15, 2008 | 10:30 PM
jonm1a1's Avatar
jonm1a1
oh ok so... is it going to be hard to change it over to a flex fly wheel
Old Jan 15, 2008 | 10:34 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
no but you gotta remove the pilot bearing out of the 302 or the trans and engine will not mate up
6bangr
Feb 15, 2016 07:40 AM
junior04
Sep 28, 2015 10:53 AM
dudeguy421
Sep 24, 2015 11:16 AM
ccdguy
Sep 19, 2015 05:20 PM
ponyride00
Aug 12, 2015 01:57 PM
