69 Mustang Coupe Sputtering
Old Jan 15, 2008 | 06:57 PM
nc_usmccouple's Avatar
nc_usmccouple
Default 69 Mustang Coupe Sputtering
I have a 69 mustang 302. Every time that i accelerate it sputters and then takes off. I know that the vaccume on the distrubitor is bad and i am going to replace it just woundering if there is anything else that ould cause it to sputter. thank you
Old Jan 15, 2008 | 09:57 PM
Daze's Avatar
Daze
Default RE: 69 Mustang Coupe Sputtering
When the accelerator pump on the carburetor goes bad it will make that exact same problem. Easiest way to check is, with the motor not running, look down the carburetor and actuate the linkage with your hand. Every time you do you should see an extra squirt of gas go in to the carb. This squirt is there to compensate for the sudden change in butterfly position. As the ventury effect catches up with the flow rate the extra fuel is no longer needed and that is why after a second the sputter goes away.
Old Jan 16, 2008 | 04:11 PM
nc_usmccouple
Will the vaccume advance on the Distrubitor make it to where the accelerator pump will not work properly?
Old Jan 16, 2008 | 04:57 PM
Daze's Avatar
Daze
a bad vacuum advance and bad accelerator pump would be different issues.
Old Jan 16, 2008 | 05:12 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Get the distributor fixed first and see what happens. That should be the problem but you won't know until it is fixed. Semper Fi!
Old Jan 16, 2008 | 05:16 PM
nc_usmccouple
I just tried it and it puts fuel when i flip the shutter
Old Apr 27, 2008 | 08:10 PM
nc_usmccouple
the engine still sputters after i replaced the vaccume advance is there anything else that could cause the engine to lose power when the gas pedal is pushed
Old Apr 27, 2008 | 08:22 PM
Stepman's Avatar
Stepman
Where is your timing set? Also what vauum are you using for dist?
ShaneB26154
35
Mar 4, 2021 04:05 AM
MEISTERSNFB
Mar 31, 2020 07:50 AM
NTO_GUY
Dec 24, 2015 11:23 AM
chain
Aug 17, 2015 08:52 AM
daytooday
Aug 11, 2015 09:22 AM
