4 speed shifter question!
Old Jan 21, 2008 | 03:10 PM
urban_cowboy's Avatar
urban_cowboy
Default RE: 4 speed shifter question!
Guess I just have the handle. The PO put it in, and all I know is it says hurst on the handle. Interesting on moving first gear. I may give that a try. All the factory orginal handles have reverse next to 2nd, but all the hurst stuff has it next to first. Always wondered why.
Old Jan 21, 2008 | 03:19 PM
67t5ponycoupe's Avatar
67t5ponycoupe
I learned the flipping it over trick by doing it wrong a few times
Old Jan 21, 2008 | 04:32 PM
Starfury's Avatar
Starfury
Easy way to tell if you have a Hurst shifter or not: does it have slop? The factory shifters, even when rebuilt, are still extremely sloppy. Hurst shifters have a much more positive engagement and don't flop around as much.
Old Jan 21, 2008 | 04:36 PM
67mustang302's Avatar
67mustang302
The Hurst shifter I got for the Toploader was one of their higher dollar ones, built like a tank with positive stops, and it has no slop whatsoever. VERY positive engagement, but it required me to cut the trans tunnel to get it to fit because of how it sits on the tailshaft.
Old Jan 21, 2008 | 06:52 PM
67t5ponycoupe
Starfury, the easiest way to tell if it is a Hurst is to, hmmm, let me see, look and see if it says freaking HURST on it!
67mustang302 how much did you have to cut? They cost enough I would have thought it was a bolt on.
Old Jan 21, 2008 | 08:38 PM
Starfury's Avatar
Starfury
ORIGINAL: 67t5ponycoupe
I'm sure you could put a Hurst lever on a factory shifter:-|
Old Jan 21, 2008 | 10:03 PM
67mustang302
Yeah, you could prolly put a Hurst lever on the factory shifter, but the real work is done in the shifter mechanism. And I had to cut quite a bit, to geat clearance for the shifter and a bit for the linkage.
carid
Jul 8, 2016 09:55 AM
musnicki
Sep 23, 2015 07:11 AM
Mustangmalo
Sep 6, 2015 05:22 PM
