stroker kits
Old Jan 24, 2008 | 08:52 PM
Aussie66Fastback's Avatar
Aussie66Fastback
Default RE: stroker kits
I would guess around 400 - 450, but its the increase in torque that you'll notice most.
IMO once you go over 300 - 350ish you need to be spending more money on the machine shop and the extras to ensure longevity. Hows your budget?
Hope the rest of your driveline, suspension and brakes are up to it.
Old Jan 25, 2008 | 08:55 AM
javier146's Avatar
javier146
It was around 2700 but now that I got a job it will be around 3 to 4
Old Jan 25, 2008 | 09:16 AM
urban_cowboy's Avatar
urban_cowboy
I suggest you talk with someone who can help you design your rotating assembly. I am using ADPerformance. They are not great on communication after the order, but they were great help in designing the rotating assembly I wanted.
There is alot to consider when you start building an engine. The most important thing to consider when you are shopping for cranks, rods, and pistons is what compression ratio do you want. If you can tell someone that, they can help with the stroke, rod length, piston compression height, dish/dome, etc. The stroker kits I have seen for the Windsor are good, but you have very few options in CR unless you build your own.
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
flash_xx
Oct 16, 2015 07:23 AM
Drastang
Sep 30, 2015 03:48 AM
