speedo help!!
Old Jan 26, 2008 | 06:05 PM
1970coupe's Avatar
1970coupe
Default speedo help!!
well my speedo doesnt work. I took out the cluster and the black rod inside doesnt spin from the inside of the car. i took it out of the trans and it has a yellow gear in it that has hardly any tention and i turned the gearasmy dadwatched the rod andit wasnt spinning on the other end. Wheres my problem? I think the gear is broke possably cause it spins freely. What do yall think it is? Do i needa new cable?
Old Jan 26, 2008 | 08:37 PM
Mustang Dad's Avatar
Mustang Dad
Default RE: speedo help!!
A new cable is the first place to start. They are cheap and relatively easy to replace. Pull the old one out, lube the snot out of a new one and slide it in. Since you already have the gear on the side of the tranny out, hook the new cable to it an see if it turns the cable up at the speedo.Put everything back together and take the car out for a spin. If the speedo still isnt working, then you have narrowed it all down to the gear on the tranny output shaft. To replace that gear, you'll have to pull the rear shaft housing on the tranny. Hope this helps.
Old Jan 26, 2008 | 09:02 PM
mustangmatt63's Avatar
mustangmatt63
Sounds like a broken speedo cable as Mustang Dad said!Should be an easy and cheap repair!!Good Luck with it![8D]
Old Jan 26, 2008 | 09:05 PM
1970coupe's Avatar
1970coupe
ok cool. yeah im shipping off my gauges this week to be totally referbished with leds and white gauge faces so it should be neat to fix it all!! cant wait
67LimeCoupe
Nov 25, 2015 08:55 PM
Mr. D
Tuner Central
Aug 27, 2015 05:01 AM
Mr. D
Wheels & Tires
15
Aug 22, 2015 02:58 PM
Gregz
Aug 11, 2015 03:42 AM
qwikhuh
Dec 1, 2003 04:26 PM
