T5 buying opprtunity UPDATE with pics
Old 01-31-2008, 06:31 PM
Gun Jam
Moderator
Gun Jam's Avatar
Default T5 buying opprtunity UPDATE with pics
hello
I have a chance to pick up this t5 http://fresno.craigslist.org/pts/556313673.html I called him and it sounds like all the parts are there but may have broken gears. 30.00 for this trans is a safe buy even if the guts are totally destroyed Im only out 30.00 bucks.
What do you guys think I should do....at what point is it not worth messing around with it?
If I wanted to ask him for the tag number so i could identify the trans such as 1352-xxx where is that number indeed located on a tag bolted to the tail housing?
Thanks for you advice
-Gun
**UPDATE**
well it turns out its a NWC out of a Ford 1983-84 T-Bird/Mustang 2.3 L4 Turbo. I dont really feel like throwing any money at a NWC but I am going to use it for fun. Ill practice removing major componets and learning their names so if i find a trans worth salvaging ill know whats wrong with it. I can also use this guy as a core parhaps if the need arises.
Here are the links to the photos.
http://www.3rflying.com/t51.jpg
http://www.3rflying.com/t52.jpg
http://www.3rflying.com/t53.jpg
-Gun
Gun Jam is offline
Old 01-31-2008, 06:39 PM
choefle
choefle's Avatar
Default RE: T5 buying opprtunity need advice
For $30, I would pick it up and have your local transmission shop rebuild it with the G-Force kit.
choefle is offline
Old 01-31-2008, 06:47 PM
Gun Jam
Moderator
Gun Jam's Avatar
what if I wanted to rebuild it with the g-force kit
what would that cost?
Gun Jam is offline
Old 01-31-2008, 06:55 PM
choefle
choefle's Avatar
I think the kit is like $1100. The World Class rebuild kit is much lower.
choefle is offline
Old 01-31-2008, 06:59 PM
Gun Jam
Moderator
Gun Jam's Avatar
1,100 is way more than I want to spend
but putting 300 or 400 out for rebuild would be fine.. I think I have seen them on ebay for about that price does 400 sound like enough to get a wc rebuild kit?
-Gun
Gun Jam is offline
Old 01-31-2008, 07:05 PM
Oxnard Montalvo
Oxnard Montalvo's Avatar
You won't know what you'll need to put into it until you take it apart. But for thirty bucks how can you go wrong? Grab it.
Oxnard Montalvo is offline
Old 01-31-2008, 07:12 PM
Gun Jam
Moderator
Gun Jam's Avatar
thats what I was thinking. If i get there and the input and output shafts are where they belong ill probably buy it.
-Gun
Gun Jam is offline
Old 01-31-2008, 07:29 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
you can get almost 30 bucks from scrap alum if its bad[8D]
rmodel65 is offline
Old 01-31-2008, 09:16 PM
Daze
Daze's Avatar
$30.00 is a steel. Gears are about 50 -100 each and a main shaft can be upwards of $300 so if the guts are bad you may have a serious price tag. A good rebuild kit with all the small parts is about $200 and I recommend an improved countershaft stabilizer $60 and a solid steel input shaft NOT A 2 PIECE or aluminum type!!! I just rebuilt mine and have about $400 in to it including a new main shaft (lucked out and got one on ebay for $80.00 shipped simply because it had no spedo gear hole) I have lots of good info if you want to tackle the rebuild your self and can help you decide what to replace and what to keep. Let me know if I can help any further
Daze is offline
Old 01-31-2008, 09:43 PM
PONYBOY65
PONYBOY65's Avatar
good deal! buy it and run! i just bought one on ebay for 600 rebuilt with bell housing, clutch fork, and Hurst Indy shifter and cant wait to put it on my mustang!
PONYBOY65 is offline
Quick Reply: T5 buying opprtunity UPDATE with pics
