FMX tranny
Old Feb 6, 2008 | 01:16 AM
Loza_69Mach1's Avatar
Loza_69Mach1
Default FMX tranny
sup you guys... i have an FMX tranny 3 speed in my 69 mach1.... i just wanted to see if anyone has changed it out and put a 4,5 or maybe 6 speed in it... like is it worth it.. will it take value off the car...
i jut hate driving on the freeway like 70 mph and its really loud and sounds like the motor cant go anymore... i just got the FMX rebuilt with my uncle so i didnt pay much to get it done... and got the 351 rebuilt to.... i just wanted to see what have you guys done for this.... anything ??
jr
Old Feb 6, 2008 | 01:55 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: FMX tranny
the 5spd swap is very popular and adds a siginifcant amount of gas mileage, and quites the cars at speed, pretty much making it cruise like a late model. check out the faq i believe theres some swap info in the faq if not do a quick search basically youll need a t5 froma 5.0 mustang 1986-1993 a 28oz flywheel,clutch, pilot bearing, a new crossmember, pedal setup,cable and to shorten the drive shaft approx 1inch
Old Feb 6, 2008 | 05:40 AM
Fordication's Avatar
Fordication
Man what rear end gears do you have? I have 2.8 something in mine and it cruises at 80 with no noise whatsoever. I would suspect you have other troubles. But if you are going to do a swap and you want an easy one then I would do an AOD.
Old Feb 6, 2008 | 07:56 PM
flyingfool's Avatar
flyingfool
Im working on a T5 right now. was pretty simple and straight forward to work with. still have to put it in however. and im also doing from three speed standard.
but, yeah, i hit 70 and things get spun pretty tight and loud as well.
Old Feb 6, 2008 | 08:14 PM
Loza_69Mach1
mmm yeah i just want to be cruising and not at a high rpm... does anyone know how much it would cost me to do that swap.... with me buying the t5.... its an automatic and prolly would get a t5 auto again... cuz changing it to a stick would be to much work... right?
Old Feb 12, 2008 | 11:35 PM
flyingfool's Avatar
flyingfool
never done it myself, but seems doable from what ive read. adding pedals, (i believe there are holes even if you have auto?) clutch and new trans i guess you could say its similar to a cltuch change?
guitarman376
Sep 30, 2015 05:54 PM
treesloth
Sep 28, 2015 07:03 AM
2poor4u2
Sep 26, 2015 11:08 AM
prophotog
Sep 15, 2015 08:38 AM
jaiidutch
Sep 14, 2015 10:29 AM
