Improving the power steering?
Old Feb 13, 2008 | 08:10 AM
jamieNerikas66stang's Avatar
jamieNerikas66stang
Default RE: Improving the power steering?
contact chocko stang,...they have awesome knowledge and awesome rebuild service with show quality work...i was speechless with the befores and afters of my steering unit,...
ask for Dan, hes the man,...its a wife and husband run company,..
Old Feb 13, 2008 | 09:22 AM
htwheelz67's Avatar
htwheelz67
you can install a tee in both the high pressure and return hoses, then install a needle valve between them, this will allow you to bleed off some of the pressure and make the power steering not so "powered"
Old Feb 13, 2008 | 01:42 PM
flyingfool's Avatar
flyingfool
htwheel, do you have pictures of that? do you have a needle valve on each line, or are they conected together by the needle valve?
Old Feb 13, 2008 | 05:32 PM
jlp66stang's Avatar
jlp66stang
You can't run powersteering without a pump. The powersteering valve is designed to direct fluid to the ram, one direction or the other. If youput that much pressure on the ball stud in the valve without fluid it will come apart, then you will be along for the ride!
Old Feb 13, 2008 | 08:36 PM
Ste7of1's Avatar
Ste7of1
Good article on rebuilding steering box in current Mustang Monthly (Mar 2008).
Ste7of1
Old Feb 13, 2008 | 09:02 PM
htwheelz67's Avatar
htwheelz67
I made my own 20 years ago on a cougar but go to www.performanceonline.com and search part#18580 its a readymade valve just for that purpose.
Old Feb 13, 2008 | 11:20 PM
Aussie66Fastback's Avatar
Aussie66Fastback
http://www.performanceonline.com/sto...855&page=1
brilliant!
jwog666
Dec 27, 2021 08:09 PM
lincolnshibuya
Dec 8, 2020 01:49 PM
logan409
Sep 26, 2015 07:43 PM
Sep 25, 2015 06:58 PM
