she wont start
Old Feb 9, 2008 | 07:57 AM
slick66stang's Avatar
slick66stang
Default she wont start
i parked my car on level ground last night and this morning went out to start her up. all she is doing is turning over and over. i know its a ongoing ordill but i need help
Old Feb 9, 2008 | 08:14 AM
stangimgood's Avatar
stangimgood
Default RE: she wont start
is there gas? spark? can it be related to your cold start problem with the choke? have you done anything about the choke?
Old Feb 9, 2008 | 08:49 AM
slick66stang
i have gas and spark and i have it choked. could it be my alternator
Old Feb 9, 2008 | 08:52 AM
stangimgood
well you have spark and gas....is the spark strong? try a shot of starting fluid?
Old Feb 9, 2008 | 08:57 AM
slick66stang
brand new plugs and wires all gapped to factory spec and i did 1 shot of starting fluid but shes not even trying to starr all she does is just turn over
Old Feb 9, 2008 | 11:04 AM
kalli's Avatar
kalli
Hiya,
100% sure its not the alternator. the alternator is only there to charge the battery. You can run a car without an alternator no problem until your battery dies.
you need 4 things to start it:
1. a starter and battery (obviously that works when it's turning over)
2. fuel
3. spark
4. compression
to 2.
how do you know you have gas ? you can either:
- get rid of aircleaner, push the throttle and see if there's gas coming through
- disconnect the fuel hose from carb and put the hiose into a container (so you don't spill). start engine. does the fuelpump provide you with fuel? take out the petrol filter in carb if you can or make sure it's clean
- try pouring half a shotglas full of petrol into the carb from top. does the sound change when trying to start ?
to 3.
if you have a good known spark plug lying around, connect it to 1st cylinder spark lead. hold thread to engine or ground with electricla plier.
Turn over engine. do you get a spark? if yes: blue or orange ?
to 4. does the engine sound like whop whop whop when starting or is it rather a weeeeeeeehhhhhh ?
measure compression if you have a compression reader
Old Feb 9, 2008 | 01:06 PM
slick66stang
i dont have a compression reader but i replaced my altnerator and she started right up for me. i had the old one tested and it was bad
Old Feb 9, 2008 | 02:26 PM
JohnnyK's Avatar
JohnnyK
As stated, it wasn't the alternator.. Unless you had some weird electrical problem.
Old Feb 9, 2008 | 05:43 PM
67mustang302's Avatar
67mustang302
Was the alternator siezed? If the pulley was frozen it could prevent the engine from turning over fast enough to generate the needed compression to start.
Old Feb 9, 2008 | 06:06 PM
slick66stang
my alternator was siezed up the little fan wont even free spin with me doing it by hand.
