Please Help with wheels
Old Feb 13, 2008 | 11:26 PM
MonsterB's Avatar
MonsterB
Default Please Help with wheels
I have asked several times about wheels for my 66 and cant get an answer. I am looking for 17 or 18 inch wheels for the coupe.
What back space do they need in the front and the back?
I am looking for something like the fr500s in that size or a wheel that looks like the torque thrust.
i am ready to purchase but need to know where to go. i emailed the wheel shops linked from this sight and never heard back.
I am in AZ and need these to get the car rolling around.
Thanks
Old Feb 14, 2008 | 01:38 AM
five pt oh's Avatar
five pt oh
Default RE: Please Help with wheels
with a 17" or 18" rim, you should have a wide range of choices. To find the exact backspacing you need, you first must figure out how wide of a wheel you are going to run.
The following is a list of optimal* BS for different rim widths for a 64-66.
Width BackSpace
5.5" 3.5"
6.0" 3.75"
6.5" 4"
7.0" 4.25"
8.0" 4.75"
8.5" 5.0" (I'm not sure ifarim wider than 8" would fit though)
*If you deviate from the numbers above, the rim might still fit, butwill not line up in the center of the wheel well. That will limit the width of the tire that can be used.
ORIGINAL: MonsterB
it shouldn't be too hard to find a torq thrust that fits a 66, but the fr500 might be kinda tricky.
Old Feb 14, 2008 | 01:17 PM
03Maverik's Avatar
03Maverik
Dodgestang has a good chart for reference. Check him out!!!
Old Feb 14, 2008 | 10:04 PM
jmstang68's Avatar
jmstang68
If your looking to put 05 or newer rims on, I believe they all have an offset of 6 inches. You would need to run a 2" spacer in the front to clear the upper control arm. Rears you could run an 1.5" spacer. That is what I have done with my 68.
Old Feb 14, 2008 | 10:50 PM
Iskwezm's Avatar
Iskwezm
i run TT2's in a 17X7 in the fron and 17X8 in the rear on my 65FB with 215/45's and 275/40's
Old Feb 15, 2008 | 10:51 PM
MonsterB's Avatar
MonsterB
five pt ohthanks for the info. do those #'s hold true for the front as well? i am trying to look up dodgestang but cant seem to find it. i am new to the isght. How about a pointer?
Old Feb 16, 2008 | 01:08 AM
andrewmp6's Avatar
andrewmp6
Heres a nice long list http://www.dodgestang.com/Tire%20Fit...ide%2065-6.pdf
Old Feb 16, 2008 | 10:43 AM
Egg Man's Avatar
Egg Man
If you like "Bullitt" style wheels you can buy them brand new off ebay for about $700. They bolt right on to a 5 lug classic stang with no spacers needed. I am running some black ones with 235/45/17 in front and 245/45/17 in the rear and they look sweet. You should give them a look.
[IMG]local://upfiles/89770/CE39E5106F494CD78C4948A6E2BBBBFD.jpg[/IMG]
Old Feb 17, 2008 | 06:30 PM
five pt oh's Avatar
five pt oh
ORIGINAL: MonsterB
yes. Those numbers should hold true for the front and rear. I got 235s to fit in front on a 15x6 rim. There's no way I could have done that without the perfect backspacing/rim size.
BTW: I talked with Dodgestang quite a bit before I selected my setup.
jwog666
Dec 27, 2021 08:09 PM
UrS4
Oct 3, 2015 06:23 AM
mungodrums
Sep 28, 2015 10:54 PM
folivier
Sep 26, 2015 02:28 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
