Clutches, return spring.....
Old Feb 17, 2008 | 09:39 AM
zmetalmilitia's Avatar
zmetalmilitia
Default Clutches, return spring.....
I need to know if I need the big return spring for the clutch pedal that is under the dash at the firewall, if I go with a clutch or hydraulic stlye clutch? It looks like installing a new pedal return spring would be a pain in the. Also, is there a clutch pedal stop that mounts somehwere in there? And if so, where does it mount? On the pedal, pedal support braket, etc. Any tips for installing this would be helpful, and pics would be great too! Thanks.
Old Feb 17, 2008 | 09:47 AM
JMD's Avatar
JMD
Default RE: Clutches, return spring.....
If you install a diaphragm style clutch (I would advise a diaphragm clutch) hyd actuated clutch, or a cable actuated clutch, you need to ditch the spring!
The only clutch stop on our 66 is the floor! There is a stop that keeps the pedal from coming up too high though.
Old Feb 17, 2008 | 10:53 AM
Tims65's Avatar
Tims65
The "return" clutch spring under the dash is actually a combination assist and return spring. It can be removed even with the stock clutch linkage. Removing it will slightly increase the effort required to engage the clutch, but it really isn't a big deal and will provide much better feed back.
As for a stop, I mounted a rear end snubber under my clutch pedal to limit the clutch travel.
Tim
Old Feb 17, 2008 | 04:32 PM
67mustang302's Avatar
67mustang302
I'm running hydraulic, ditched the spring and fab'd a positive adjustable stop, mainly cuz I need to limit the m/c travel to no more than 1" or it could blow the internal seals.
Old Feb 17, 2008 | 07:26 PM
JMD's Avatar
JMD
ORIGINAL: Tims65
Nice looking stuff man!!
Tim
Old Feb 17, 2008 | 11:58 PM
zmetalmilitia
Ok cool, that's what I thought. I was trying to install this spring and after looking into a couple of sites, I read the spring isn't needed if running a different style of clutch. That spring looks to be a real hassle to try and get in. I think I will see into the rubber snubber thing, I may want that too. Thanks for the input.
Thunderball
15
Nov 22, 2015 11:49 PM
junior04
Sep 28, 2015 10:53 AM
MacSerio
Sep 27, 2015 01:05 PM
ccdguy
Sep 19, 2015 05:20 PM
MasterLanMan
Sep 13, 2015 08:21 PM
