Coil Wiring?
Old Feb 17, 2008 | 10:17 AM
john721's Avatar
john721
Default Coil Wiring?
I have a 66... Which wires go to the coil on the engine feed harness? My coild has + and - posts..... Just need to know which wires go where...also from the distributor... Thanks for the help guys!
Old Feb 17, 2008 | 10:26 AM
Daze's Avatar
Daze
Default RE: Coil Wiring?
the black wire from the distributor goes on the - side of the coil and the + side goes to a hot lead that goes to the key. NOTE between the ignition switch and the coil should be a pink resistor wire.
Old Feb 17, 2008 | 02:59 PM
john721's Avatar
john721
where would this pink wire go?
Old Feb 17, 2008 | 05:27 PM
cajin's Avatar
cajin
to the coil
Old Feb 17, 2008 | 05:41 PM
kalli's Avatar
kalli
might have been removed when someone upgraded to HEI/pertronix.
do you have stock setup or pertronix distributor and coil?
jwog666
Dec 27, 2021 08:09 PM
firehorse02
Nov 16, 2015 11:28 AM
Dathan
Oct 5, 2015 05:52 AM
Sixer4Life
Sep 28, 2015 07:05 AM
lmurf60
Sep 24, 2015 10:07 PM
