connectng rod question
Old Feb 17, 2008 | 07:11 PM
racin66coupe's Avatar
racin66coupe
Default connectng rod question
http://cgi.ebay.com/ebaymotors/NASCA...QQcmdZViewItem
if i get a 4in stroke crank, can i use these rods and what ci would i get? oh yeah, its a 351w
isit even possible use rods not specfic fo the engine/crank?
i also saw some with 6.250in length, will something like that work also?
Old Feb 17, 2008 | 08:59 PM
cprstreetmachines's Avatar
cprstreetmachines
Default RE: connectng rod question
I'd pass honestly. Customers of my local machine shop have tried to use them. Only to have found them over heated, or completely usless for a number of reaons.
Old Feb 17, 2008 | 09:36 PM
JMD's Avatar
JMD
Without researching, they look to me like the rods are the wrong size on both the bid end and the little end...
Price some new Scat's that actually fit, you can get new H beams for not much more!
A 4.030 bore combined with a 4.000 stroke = 408 CI..
Rod length will be determined by
Deck height = Stroke + Piston compression height + rod length -about .003 (-.003 optional)....
Old Feb 17, 2008 | 09:53 PM
my77stang's Avatar
my77stang
i believe these are the high dollar rods used in the nascar motors, they have different crank journal diameters..... but should be VERY high quality parts
Old Feb 17, 2008 | 09:54 PM
67mustang302's Avatar
67mustang302
You can get a set of decent rods these days that are brand new, with floating pins, that'll take more buse than your block, for under $300. Well, if it's a stock block anyway.
racin66coupe
ok thanks guys
chrisdbassplayer
Oct 13, 2015 06:53 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
treesloth
Sep 28, 2015 07:03 AM
gagemcc
Sep 22, 2015 09:43 AM
