Sheet metal - Cowl
Old Feb 18, 2008 | 08:23 AM
JeffsStang's Avatar
JeffsStang
Default Sheet metal - Cowl
I was setting out on my cowl repair project, when I noticed in the catalog that you can buy a replacement upper and lower cowl already put together, etc. I was originally going to go through the normal cowl fix of drilling the spot welds, removing the top, repairing the hats and reinstalling the top. Now, I was thinking about just replacing the top and bottom as a unit. Has anyone done this? I can't see how you would remove the bottom (of course I don't have the top off yet and it may become obvious then). Is it worth buying the complete unit and doing everythng at once?
Thanks,
jeff
Old Feb 18, 2008 | 08:46 AM
gooser's Avatar
gooser
Default RE: Sheet metal - Cowl
whose catalog?
Old Feb 18, 2008 | 08:48 AM
usmc69mustang's Avatar
usmc69mustang
I just bought the complete unit for my 69 and it wasn't as easy as I thought. It was difficult to strip all of the EDP coatingfrom between the upper and lower piecesso I could lay down primer. They sell the upper and lower as separate pieces and that is the way Iwould go if I had to do it over again. More welding, but I think you would have a better product in the end.
Old Feb 18, 2008 | 08:50 AM
usmc69mustang
Mustangs Unlimited sells them and CJ Pony parts does as well. I bought mine from MU.
Old Feb 18, 2008 | 09:10 AM
JeffsStang's Avatar
JeffsStang
I'm looking at the CJ Pony Parts catalog since they are only 20 mins away from my house (saves shipping cost).
My car is a 68 coupe. I assumed the inside would already be primed and painted black??
What holds the existing lower section in?
Old Feb 18, 2008 | 11:24 AM
choefle's Avatar
choefle
Check out this articlefrom Mustang Montly, it ison the 67-68 cars, but the steps are the same for the 64-66 cars as well. Dynacorn makes the 64-66 assembly, but you can also get the 64-66 upper and the 67-68 lower and move the wiper motor mount. This will allow you to paint and apply some rust inhibitor to the inside section of the cowl.
It is a lot of work, but well worth it.
Old Feb 18, 2008 | 11:27 AM
choefle's Avatar
choefle
usmc69mustang, why would you remove the EDP coating? You can primer and paint over it and it is a very good rust inhibitor.
Old Feb 18, 2008 | 10:38 PM
john721's Avatar
john721
I chose to just replace the bottom. I like knowing I could coat the lower cowl pan and the underside of the upper with POR-15 before I reassembled it. The "hats" come installed on the lower pan too. It really wasn't that bad.....
http://i183.photobucket.com/albums/x...wlpainted2.jpg
http://i183.photobucket.com/albums/x...owlexposed.jpg
http://i183.photobucket.com/albums/x...wercowlfit.jpg
jrrhd73must
Oct 2, 2015 09:17 PM
KingRando
Oct 2, 2015 08:06 AM
UrS4
Sep 30, 2015 10:13 AM
mungodrums
Sep 28, 2015 10:54 PM
mrappe
Sep 26, 2015 10:16 AM
