Getting closer to paint
Old Feb 19, 2008 | 12:39 AM
HGC's Avatar
HGC
Default Getting closer to paint
Hoping for paint in April. Got the area behind the headlights cleaned out and primed. The one small hole I found was apparently caused from a hole in the splash guard which let water into tiny area and then trapped it. I patched that with epoxy. There was a lot of rust in the bottom of headlight openings but I got it all out down to metal. The part between the headlight openings and the engine compartment (don't know what part it is - the wiring runs through it) wasrusty and I could not get to all the rust to sand it. Thoseareas I scraped as clean as I could with a flat screwdriver and then used Rustoleum Rusty Metal Primer for heavily rusted metal. Seems to be pretty good stuff, kind of like POR-15but takes paint better. It's a reddish color and I topcoated that with gray primer, just because I wanted it to look all gray before paint (stupid, I know). The rest of the front didn't need much work. Most of it was rust free except for a light coating of rust on the hood release mechanism. Wire brushed and sanded that off.
[IMG]local://upfiles/82474/55D95B8DECD44D69ADDC95CCCF41BC08.jpg[/IMG]
Old Feb 19, 2008 | 06:21 AM
bcs65's Avatar
bcs65
Default RE: Getting closer to paint
good luck
Old Feb 19, 2008 | 12:52 PM
HGC's Avatar
HGC
It will be the original Honey Gold. Not my favorite color but I want the original look, and I don't want to paint all the good parts like the trunk, door jambs, etc. Also, the interior is pretty much perfect and it is the Olive Gold to match. I got lucky in that I know the shop that will paint it and they are letting me do the prep work which saves a bundle. Aside from the areas in the photo and a few patches it's still original paint so I'll have a good base once I strip the wax and sand it down. It's been years since I sanded a car and I am having re-learn the "touch" so I don't sand through the primer on the corners where it is easy to put a little too much pressure. The flat areas are easy...just time consuming.
Old Feb 19, 2008 | 05:21 PM
4reboy's Avatar
4reboy
Looks great Jim, keep up the good work! I think I have that same rustoleum primer you use.
Oct 1, 2015 09:29 AM
mungodrums
Sep 28, 2015 10:54 PM
GLOCKer
Sep 28, 2015 07:36 AM
zachary1988
Sep 18, 2015 11:17 PM
mustangchef
Sep 4, 2015 08:08 PM
