CSRP brake question
Old Feb 19, 2008 | 10:24 PM
dodgestang's Avatar
dodgestang
Default RE: CSRP brake question
ORIGINAL: racin66coupe
dodgestang, i already have the spindles. but thanks for the advice of what you are running. is this the kit? http://mustangsunlimited.com/itemdy00.asp?T1=A120D+01
thanks
Yes but I use a different master cylinder since I put in rear discs
Old Feb 19, 2008 | 10:28 PM
racin66coupe's Avatar
racin66coupe
yeah, i was thinking of goin all disks in the future so a differnt master cylender would be in store for later
Old Feb 19, 2008 | 11:27 PM
Mustang Dad's Avatar
Mustang Dad
WE did the Granada swap on your '65 via the piece-it-together-yourself method. Used a stock manual '74 Maverick dual chamber master cylinder and they work like a champ. The manual MC gives us a better 'feel' forbraking.
Old Feb 20, 2008 | 12:37 AM
jravenea's Avatar
jravenea
Hi,
I just completed the swap on my 1968 302 with the CSRP kit. I must say it completely delivered on expectations. The stopping power with the single piston caliper is FAR better than what I had with drums.
However I didn't drive over 60MPH with it yet. Today was actually the first test on the expressway, next is freeway ;-)
A few words about the kit:
It came fast after my order and is really complete. I only had to buy pre-fabricated brake lines and brake fluid on top of it.
I followed the instructions and it was pretty easy to put together with a couple email exchanges with Dennis who provided great and fast support.
After I striked my older spindles hard enough to separate the lower ball joints, the rest of the mechanical was a total no brainer.
The plumbing was a little more challenging. Getting the hard lines properly aligned to the connection and the flare not to leak. I must say I had to redo more than once despite the pre-fabricated flare.
A couple pictures.
[IMG]local://upfiles/39927/5521A0374FAF45FA92BF62F33CC451A5.jpg[/IMG]
[IMG]local://upfiles/39927/81E0D730A7F6421987239AD5579BCDAA.jpg[/IMG]
[IMG]local://upfiles/39927/ACEBBA961CAF49FAB1C3BEC5E2EDAE56.jpg[/IMG]
[IMG]local://upfiles/39927/51774ADA6D184FEFB89336CDD8B51F4A.jpg[/IMG]
Old Feb 20, 2008 | 12:59 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
ORIGINAL: JamesW
They are what they are. They are 70s brake technology. If you're wanting bigger rotors and dual or quad piston, or even 6 piston brakes, then there are more expensive aftermarket selections.
I have Granada brakes and they are just fine for street cars as Nick said.
i was going restomod so i went big on my brakes ive got about 2k even for the both the front and rear a little overkill though for most the csrp will be the way to go
Old Feb 20, 2008 | 01:30 AM
andrewmp6's Avatar
andrewmp6
Wilwoods are overkill unless your gonna put a nasty small block in it and road race it.If your going to get the v8 spindles id go http://www.mustangsteve.com/cobrabrakes.html the cobra brakes are pbr same thing baer really is and cheaper if you want wilwoods bad http://www.hotrodsusa.com/store/brakesmustang.html
Old Feb 20, 2008 | 09:24 AM
cprstreetmachines's Avatar
cprstreetmachines
didnt you guys use the granda swap on your stang cpr? i think the mag said u did, and since you have a powerful motor.... how well do they work?
yea we did. Stoping in the 1/8 mile from 100mph it stops great but it also has rear disc brakes.
I also don't think there is overkill on safety. GO BIG OR GO HOME
Old Feb 20, 2008 | 12:08 PM
racin66coupe
i think im going to go with the kit from mustangs unlimited (the 4 piston ssbc) and just save up 400 more bucks
Old Feb 20, 2008 | 10:11 PM
andrewmp6's Avatar
andrewmp6
Just remember bigger brakes aint always best on a street car you'll have to run a street pad to keep them hot enough to work fully.Down side is your pads don't last as long.I read a magazine article a while back they had 2 miatas just a like but one had bigger brakes 60-0 stops with cold brakes the stock step up did better but on the track the big brakes gave the car a better lap time.
Tivo304
Aug 28, 2023 12:19 PM
DoctorScary
Sep 9, 2015 07:53 AM
Sep 8, 2015 11:50 AM
