Vehicle condition?
Old Apr 5, 2005 | 08:58 AM
66ConvertibleSandra's Avatar
66ConvertibleSandra
Default Vehicle condition?
Where exactly are the frame rails, torque boxes and rocker panels on my 66 convertible? Where are they and what do I need to be looking at in determining the condition of these items? Hey I'm a girl - I don't know these things.
Thank you guys![:-]
Old Apr 5, 2005 | 09:38 AM
1970 mach1's Avatar
1970 mach1
Default RE: Vehicle condition?
Your frame rails & torque boxes are located underneath your stang. Look behind your front tires at the floor boards u will see a metal box these are your front torque boxes. Take a screwdriver & pick at these boxes 2 see if they r solid. Do the same to floor pans. Go to rear of stang in front of therear tiresunderside u will see rear frame rails check them the same way. If they r not rusted through u r in good shape, u have good metal not rusted through. Beleive me I've had some rust buckets thatv I had 2 replace all kinds of sheet metal & torque boxes LOL
Old Apr 5, 2005 | 02:26 PM
Soaring's Avatar
Soaring
I ♥ Acer
Bob answered the torque box question. The frame rails are the long channel looking rails that support the body. The rocker panels are the areas underneath your doors. Along with checking the torque boxes and rocker panels, check your trunk area. Another rust trouble spot is the front bottom of your doors. And, as Bob mentioned, the floor pans because most Mustangs have rotten cowls, and water has leaked onto the floor for years, causing a soggy carpet, and thus the rust. Also take the trunk liner out and visually look for the ever present brown rust. You need to scrape, sand, bead blast, wire brush or whatever method you choose to get those areas down to clean shiny metal, then prime and paint them. For underneath, you will need to do the same. Then finish by painting it with Red Oxide paint you can get from National Parts Depot. Let us know what rust you find, how far gone it is, and where it is.
Old Apr 5, 2005 | 03:14 PM
66ConvertibleSandra
Thank you guys! You are so very helpful - I guess we'll be underneath the car tonight checking for damage!
Thanks again....you're great as is this whole forum.
Old Apr 5, 2005 | 04:58 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: 66ConvertibleSandra
Tonight? You must have one very powerful flashlight. I would jack the car up and put 4 jack stands under it on the frame rails, then check for rust in the light of the day.
baddog671
Jul 26, 2016 01:20 PM
winner99
Oct 1, 2015 01:06 PM
mdg
Oct 1, 2015 07:04 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
treesloth
Sep 28, 2015 07:03 AM
